4 members (Alan Patterson, John Wilcox, gomog, Plus Four Guy), 215 guests, and 28 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
Page 97 of 164 1 2 95 96 97 98 99 163 164
Rog Offline
Originally Posted by Deejay
Assume you have now fitted the fleabay aluminium one?
Yes, I’ve done my bit for China’s economy and my little die cast T is in.
It did need a healthy shove and a wriggle to get up the pipe
Roger
Think that’s a nicer fit than the viper one and a lot cheaper too. Also suggests that the 19mm one would simply be too much.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Received the new brake master cylinder and swapped out the pushrod. I'll install it this week.
I assume you have a locknut in the inside of the fork ?
Of course.
I had a grease seal leak behind the right rear hub. Pulled the hub, replaced the seal, put the hub back on. Then put the castle nut on and tightened it down so it lines up with the hole for the cotter pin.
I tightened it 3 times, I just need to tighten it a little more. Then it's too far, so loosen it and start again.
I must have done that 15 times until it finally lined up
Now I'm upstairs having a drink
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Or you could have just filed the back of the nut to get it to line up.....
Arwyn
Make the nut slightly thinner so the hole lines up. Hmmmm.
I'll keep that in mind for next time. How tight should that nut be? With the amount of force needed on the 3-arm puller the nut isn't doing too much anyway.
73 4/4 "Henry A"
60 MGA
I always thought that you just nip the nut up and then back off to meet the hole.
Doug
1958 Triton 650
Not my Mog but I did find the source of an annoying noise for a mate. The wing stay to the tp of the wing had lost the nut & bolt.
