8 members (Simon, Julian BB, Graham, G4FUJ, SwissMogFan, +8Rich, RichardV6, John V6, Laurens),
331
33
Topics49,915
Posts838,218
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Assume you have now fitted the fleabay aluminium one? Yes, I’ve done my bit for China’s economy and my little die cast T is in. ![[Linked Image]](https://tm-img.com/images/2024/02/24/ali-t.jpg) It did need a healthy shove and a wriggle to get up the pipe
Roger 2011 Plus 4
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
Assume you have now fitted the fleabay aluminium one? Yes, I’ve done my bit for China’s economy and my little die cast T is in. ![[Linked Image]](https://tm-img.com/images/2024/02/24/ali-t.jpg) It did need a healthy shove and a wriggle to get up the pipe Think that’s a nicer fit than the viper one and a lot cheaper too. Also suggests that the 19mm one would simply be too much.
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Received the new brake master cylinder and swapped out the pushrod. I'll install it this week. ![[Linked Image]](https://www.tm-img.com/images/2024/02/25/IMG_6457.md.jpg)
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
I assume you have a locknut in the inside of the fork ?
I assume you have a locknut in the inside of the fork ? Of course.
Posts: 810 Likes: 59
Posts: 810 Likes: 59 |
I had a grease seal leak behind the right rear hub. Pulled the hub, replaced the seal, put the hub back on. Then put the castle nut on and tightened it down so it lines up with the hole for the cotter pin.
I tightened it 3 times, I just need to tighten it a little more. Then it's too far, so loosen it and start again.
I must have done that 15 times until it finally lined up
Now I'm upstairs having a drink
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Now I'm upstairs having a drink Or you could have just filed the back of the nut to get it to line up..... Arwyn
Make the nut slightly thinner so the hole lines up. Hmmmm.
I'll keep that in mind for next time. How tight should that nut be? With the amount of force needed on the 3-arm puller the nut isn't doing too much anyway.
I'll keep that in mind for next time. How tight should that nut be? With the amount of force needed on the 3-arm puller the nut isn't doing too much anyway. I always thought that you just nip the nut up and then back off to meet the hole.
Posts: 27,853 Likes: 767
Posts: 27,853 Likes: 767 |
Not my Mog but I did find the source of an annoying noise for a mate. The wing stay to the tp of the wing had lost the nut & bolt.
