9 members (SteveT, Nickplus4, Themorganeer, Morganmike, gomog, mmalone, High Hamster, RedThree, +8Rich),
242
93
Topics49,872
Posts837,704
Posts: 10 |
I have a1971 4/4 Competition. Once running she’s very reliable and runs sweetly. Bags of power, very smooth pick up, a delight to drive. Motor is unmodified – a Kent crossflow with Weber carb and Lucas dizzy. After the car has been standing for a few weeks it takes a lot of cranking till she fires up by which time the battery is beginning to weaken. Once started, it restarts easily. Two years ago we fitted a new mechanical fuel pump and had the distributor rebuilt. Prior to this, despite the poor condition of the distributor, the car started on the second or third crank even after standing for the winter. The pump seems to be delivering with adequate pressure, no leaks, and timing seems to be spot on. Plugs are clean and have only run a couple of thousand max. Prior to these problems the car started on the second or third crank even after standing for the winter. I’m at a loss as to what to try next. Could I bypass the mechanical pump with an electric and see if that makes any difference? But as I’ve said the pump is new and seems to deliver. The advance retard on the distributor was also completely shot and was replaced during the rebuild. I’d very much appreciate any suggestions.
Many thanks!
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
My old'76 could take a bit of cranking to start after standing for a few weeks. Put down to fuel draining back from the mechanical pump. If you fit an electric pump you will also need a pressure regulator. With the delayed start at least there was plenty of oil circulating through the engine.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
My old'76 could take a bit of cranking to start after standing for a few weeks. Put down to fuel draining back from the mechanical pump. If you fit an electric pump you will also need a pressure regulator. With the delayed start at least there was plenty of oil circulating through the engine. Graham Not necessarily...I run a Facet Posiflow on my 4/4, no regulator needed. Facet Gold Top/Silver Top are complely different story though! Kind regards Arwyn
1 member likes this:
Graham, G4FUJ |
Inbuilt pressure regulator Arwyn? (I should look it up  ).
Posts: 6,672 Likes: 438
Posts: 6,672 Likes: 438 |
Duplicate thread here: https://www.talkmorgan.com/ubbthrea...problems-1971-4-4-competition#Post797343I have a Facet Posiflow on the MG with no pressure regulator, but a Facet Silver Top on the Morgan coupled with a Malpassi Filter King regulator
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Facet Silver Top on the Morgan coupled with a Malpassi Filter King regulator Yep, that's what I had on mine when I still had the CVH engine. The Ecotec has a high-pressure in-tank pump.
