6 members (Burgundymog, nick w, Luddite, TheRabbit, Robbie, John V6), 306 guests, and 79 robots.
+8Rich 77
Topics49,870
Posts837,673
Rudolf
#797579 17/03/24 10:50 AM
Content deleted.
Regards
Gary
If you are talking about excessive crankcase pressure have you checked cylinder pressures? Is oil blowing out or being used, are plugs oily etc.?
Since you mention readings though could it be engine oil pressure you are referring to? From the manual T16 oil pressure should be between 2.8 and 5.2 bar (41 - 75psi) @ 3000 rpm with warm engine.
Thanks Richard.
Now you raise the question I think it is more likely to be oil pressure. The diagram on the gauge would imply
crankcase pressure, but oil pressure is far more relevant and useful.
