7 members (TBM, Clipper, Ady42, +8Rich, Luddite, Tresco, JMcL),
322
109
Topics49,869
Posts837,660
Posts: 98 Likes: 2
Posts: 98 Likes: 2 |
Content deleted.
Regards Gary
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
If you are talking about excessive crankcase pressure have you checked cylinder pressures? Is oil blowing out or being used, are plugs oily etc.?
Since you mention readings though could it be engine oil pressure you are referring to? From the manual T16 oil pressure should be between 2.8 and 5.2 bar (41 - 75psi) @ 3000 rpm with warm engine.
Posts: 98 Likes: 2
Thanks Richard. Now you raise the question I think it is more likely to be oil pressure. The diagram on the gauge would imply crankcase pressure, but oil pressure is far more relevant and useful.
