1 members (Montegue), 289 guests, and 53 robots.
+8Rich 93
Posts837,277
Page 3 of 4 1 2 3 4
aerotaff #797882 24/03/24 10:15 AM
You have a PM Nick 😎
Clemens
PlusFour Red Baron MY 2022
aerotaff #797903 24/03/24 02:21 PM
The folding mini wind block looks a well thought through design.. is it possible to gather some dimensions of it extended?.. The Plus Six is wider than the Plus Four, so any dimensional info would help to see if it could be fitted.
Dave
Plus Six "Squeak"
Roadster departed.
aerotaff #797924 24/03/24 05:50 PM
With the Pin, the wider Part is about 110 cm. I just put this on my PlusFour as a test.
Clemens
aerotaff #797929 24/03/24 06:24 PM
The frame on yours looks thicker than on my older one...I wonder if there are different models/sizes?
Pm sent to you
aerotaff #797931 24/03/24 08:13 PM
Pictures from Nick
Clemens
aerotaff #797934 24/03/24 08:29 PM
Thanks Nick & Clemens thumbs
aerotaff #797937 24/03/24 09:32 PM
I made a slip-on wind breaker for my PlusFour CX headrests which works very well. Doesn’t need any fittings and the material just folds up flat when not in use.
[Linked Image] [Linked Image]
Created it from a sheet of wind deflector material from here: Wind Deflector material. Sewed some webbing to three edges of a 29” wide by approx 20” long section, then fitted elastic to the edges such that 8” folds over top and down the front of the headrest, with the remaining 12” down the back of the seat.
See photos - hopefully they explain how to make it…
[Linked Image] [Linked Image] [Linked Image]
(Was posted previously here: https://www.talkmorgan.com/ubbthreads.php/topics/785308/my-top-twenty-cx-tweaks)
aerotaff #797938 24/03/24 09:52 PM
That's neat.
aerotaff #799273 22/04/24 12:55 PM
Does it help with the wind noise at all?
aerotaff #799291 22/04/24 06:46 PM
My perspex blocker doesn't reduce noise at all, but does reduce buffeting from the rear.
Page 3 of 4 1 2 3 4
