1 members (Julian BB),
268
83
Topics49,847
Posts837,389
Posts: 29 |
Dear Morgan Family, Is it possible to change an +8 3,94L 1997 rover engine in Liquefied Petroleum Gas, LPG Autogas Power? Where is then the Gas Tank? Greatings from Germany riri
Greatings from germany, +8 1997 3,9 l blue
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
It was done in the USA. The tank replaces the petrol tank.
Posts: 29 |
And the koldstart? The engine begins with benzin and switch after about 2km to LPG. So the engine needs a little bezin tank. It was done in the USA. The tank replaces the petrol tank.
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Some info here on US Morgan +8's. It suggests early injected models were converted to run on LPG as well with no mention of petrol start.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
The propane powered Morgans do not have a different starter motor and then swap over, the engines are either run on gasoline or propane the tanks are swapped out along with other bits and bobs. There are still some propane powered Moggies over here but the majority have been converted back to gasoline as it is a way more convenient fuel.
I remember at one stage looking at LPG for C class Merc. In those days in the UK you lost the boot space to propane but the car was dual fuel. You could start it on either. I didn't think the pay back was good enough.
Posts: 29 |
In germany is the LPG cheaper than E10.
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
There is no dual fuel. Only Propane or Gasoline. The propane tank is where the normal gasoline tank would go. The spare does fit higher on the Propane car as the wooden bracketry is removed and the spare wheel mounts directly to the propane tank.
I have converted a good number of US (Bill Fink) propane cars to Gasoline. Both Plus 8s and 4/4s. Not all that difficult. The hardest part is creating the wooden bracketry for the spare wheel.
Cheers, Mark
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
I had a land rover than I had converted to LPG - it was much cheaper than petrol and I could get a comparable mpg to petrol so paid for itself in 12 months.
I had twin underseat petrol tanks (ex MOD) and the lpg tank was in the rear bed. Gave me a great range, and removed the anxiety of finding an lpg station to top up (there were four near home, work, or mid commute). However, at least 3 of them are now gone.
There are plenty of kits out there for both carb and efi models. Tank wise, you could go for a toroidal tank which would fit where the spare wheel should go, or a small custom made petrol tank next to a small lpg tank.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
+8 propane conversion pioneered by the late Bill Fink of ISIS motors IIRC.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
