3 members (MJF, Bunny, Massi_torino), 170 guests, and 83 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,628
Moggo
Page 4 of 4 1 2 3 4
And what modification was that?
Gordon
2013 M3W
1972 MGB Roaster
1967 Morris Mini Super Delux
Originally Posted by rcmatt
so the "sump issue" the x wedge has an external sump.... fine and dandy!... But the X-wedge is not a modern engine. Oil from the external sump leaks past the seals and ends up in the bottom of the x-wedge (mine fills up with at least 1.5 quarts). when you start the engine this gets forced up through the vent system into the intake (and also back to the external sump.
REALLY stupid way to configure an engine... but heck! it is a MORGAN
Mine no longer does that, it just pumps the oil back into the tank.
Same as mine. I have Emil's Custom Morgan kit installed.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Wow……
Just WOW
Trouble with this is that it will be illegal in most countries as its venting oil straight to the road surface.
Raphy - you can get away with it in France at the moment but the Control Technique (MOT) for motorbikes/m3w's becomes compulsory next year....
Not a great modification for other road users such as motorcyclists?
Pipe should vent into a catch tank....its not difficult to acheive.
Hi Steve
Great you keep track of the Control-Technique in France.
But . . .
As far as I am informed it is only for Light motorbikes.
see
https://www.dekra-norisko.fr/le-con...ut-savoir-sur-la-reglementation-id-11017
Quote :
The categories of motorcycles concerned by technical inspection are as follows:
L4e: Category L motorcycle with sidecar
L3e-A1: Motorcycle less than 125 cm3
L3e-A2: Motorcycle intended in particular for young licenses below 35kW and weight/power ratio less than 0.2kW/kg
L3e-A3: Other motorcycles
And we - M3W - are registered in category : L5e
Like to hear when my info is wrong.
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
Originally Posted by Herrie
Hi Steve
But . . .
see
Quote :
Hi Herman - the CT will now cover all class L vehicles:
"Roadworthiness tests shall cover 2- or 3-wheel motor vehicles and motor quadricycles (L-category vehicles): motorcycles, scooters, quads..."
https://www.service-public.fr/particuliers/vosdroits/F37538?lang=en
I think the Dekra website you link to is only concerning motorcycles....?
As it involves French bureaucracy, I'm sure there will be some confusion regarding its implementation or not...
The search engine on this site is iffy at best
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
1 member likes this: LightSpeed
Page 4 of 4 1 2 3 4
