4 members (Graham, G4FUJ, CooperMan, John V6, thierry242), 340 guests, and 39 robots.
+8Rich 71
Adam12 69
John V6 57
9,215 Registered Users
by +8Rich - 01/08/25 06:24 PM
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,370
Posts813,482
Members9,215
Dreiradschubser
Dreiradschubser
Dear friends,
I would like to roughly explain to an experienced mechanic who has never worked on a threewheeler how to replace the rollers / inlets in a compensator that has been rebuilt by Bleazy.
What are the basic steps involved, is there perhaps a description or a video?
Additional question: does it make sense to lubricate the new inlets with silicone or another material? If so, what do you recommend?
Many thanks and best wishes from Waldemar aka Michelwald from Cologne, where the tricycle season is about to begin
Refer them to Phil Bleazeys website, or request from Phil directions, which I believe ships with his conversion. Always best to go to the original source, if available.
http://www.bleazey.co.uk/M3W.html#Cush
Late 2012 M3W
1 member likes this: LightSpeed
Dreiradschubser
Dreiradschubser
Thanks a lot, I got the right informations from m3wService
Waldemar alias Achim
See
smile
That video is spot on. Once I did the Bleazey Conversion it made me wonder why MMC did it the way they did, unless they are selling shop time as part of the MMC experience.
Has Phil figured out his crank shaft issue yet? I see he is still not selling, just installing. Although I presume he is still trusting in Craig over at M3WServices since Craig is also installing.
Craig - Texas, USA
2021 M3W
M3WServices in the EU are no longer installing the PB Centa, they are installing a modified inner rotor as this does not need the outer rotor to be separated from the crankshaft which is where the issue with the PB upgrade occurs.
PB to my knowledge is only installing at his workshop in Lancaster and is no longer selling kits to 3rd parties for installation.
1 member likes this: CraigL
What crankshaft issue is this if I may ask?
Gordon
2013 M3W
1972 MGB Roaster
1967 Morris Mini Super Delux
It has been known in exceptional cases for the securing nut to come loose due to the poor machining of the crank shaft splines. Phil has the rotor splines machined undersize and then finishes them off by hand to exactly match the crank it is being fitted to, so they become a matched pair.
If the cranks were machined to any decent tolerance this would probably not need to be done.
Thanks Dab of oppo
Gordon
2013 M3W
1972 MGB Roaster
