7 members (Stephen888, Ian Wegg, linklaw, tezzer, Pittsartist, Alistair, Robbie),
262
79
Topics49,853
Posts837,447
Posts: 1 |
Near side window hard to slide open from new . Tried silicone spray lubricant which seemed to make sliding harder ( maybe swelled seal ? ) noticed someone had mentioned trying graphite. Used a product that I had to hand which is used for lubricating door locks. Worked a treat, very effective.
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
I attempted to take perspex out of sidescreens the other day but gave up before I did damage. In the process I used a small powerful car vac to clean out channels aided by a thin plastic scraper, cloth and solvent. A surprising amount of muck came out and the previously stiff passenger slide now runs a little smoother. Remember anything that lubricates will attract muck as well.
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
You used to be able to get a spray on 'dry lube' I think it contained PTFE
There is a WD40 variant dry lube with PTFE available here.
