8 members (TBM, IcePack, Graham, G4FUJ, Montegue, JohnHarris, Image, RichardV6, bmgermany),
390
47
Posts837,279
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Actually Kevin it's called Amazing Goop! Sorry for that! Had that niggling itch at the back of my neck so had to check!
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Just a little tinkering but important for me. I also use my smartphone as a sat nav. In addition to the smartphone holder I made, I now needed a charging socket with more power (PD/ QC3.0). Because I don't like to destroy or change original parts I made a new radio slot plate.. I still had suitable vinyl to cover a new radio slot plate from some other conversions (door pockets etc.). Many USB sockets consume power even when not in use. To avoid this, I just had to get a USB socket suitable for my purpose and an adapter plug to fit the original Morgan loom. ![[Linked Image]](https://tm-img.com/images/2024/04/08/USB_On-Off.jpeg) Ignition/ USB-socket "Off" and "On" ![[Linked Image]](https://tm-img.com/images/2024/04/08/Phoneholder_800x1067.jpeg) My phoneholder in use
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
I had exactly the same issue Kevin several years ago. Re-glueing worked for a while but whilst having some trim work undertaken at Allon White I mentioned it to Sean. By then it had failed again and his answer was that nothing short of a new seal would work long term. I had him fit one there and then. It's been fine ever since and more watertight as he took care to cut only the minimum of rubber to clear the sunshade mounts on screen surround. I did ask if silicone grease would ease fitment of header rail but he didn't recommend it!
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
I had exactly the same issue Kevin several years ago. Re-glueing worked for a while but whilst having some trim work undertaken at Allon White I mentioned it to Sean. By then it had failed again and his answer was that nothing short of a new seal would work long term. I had him fit one there and then. It's been fine ever since and more watertight as he took care to cut only the minimum of rubber to clear the sunshade mounts on screen surround. I did ask if silicone grease would ease fitment of header rail but he didn't recommend it! Thanks Richard. At least I know there's a solution eventually if this remedial work fails.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Not polished, just waxed today. I have a pretty good wax, polished a year ago, first time in ten years. It's nice how you can cut an object out of a photo at the touch of a button these days. ![[Linked Image]](https://tm-img.com/images/2024/04/12/IMG_4689.png) ![[Linked Image]](https://tm-img.com/images/2024/04/12/IMG_4688.png)
1 member likes this:
Ruut Bianchi |
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Posts: 879 Likes: 31
Posts: 879 Likes: 31 |
Bert & B1800 "Tis well enough to know how much to know; and when to know, not to know, too much."
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Shiny !
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Well done Heinz 👍
Clemens
PlusFour Red Baron MY 2022
Changed brake fluid with the help of  on the pedals.
