2 members (Socalm3w, sprinty),
336
53
Topics49,844
Posts837,360
Posts: 8 |
Hi, can any one tell me what cylinder Morgan use on the roadster? Thanks John
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Think all post 93 cars with rear hub brakes use the CW 15953 cylinder either by Delphi or Lockheed. Try wolf performance for a good price. Not really worth shopping around too much as the location pins can be positioned in different places. IKf you're doing it yourself its worth ordering the installation tool as well, about £14 but makes the job quick and simple.
Ah! if it's post 2017 to 2020 they are different again!
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Here you are use this link
Also try power track Ltd. my last one's from there and they were cheaper!
Posts: 8 |
Thanks for such a speedy response!
That is what the site is about. Good luck
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
The tool to help get the clip over the rear spigot is the same as a Classic Mini and are available online for around a £5iver, if you don't want to pay inflated Morgan parts prices
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
Ah! if it's post 2017 to 2020 they are different again! Yes this happened on 30/3/2017 with rear cylinder part number change to Y220002. Important for later models as apparently the roll pin is in a different position.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
The tool to help get the clip over the rear spigot is the same as a Classic Mini and are available online for around a £5iver, if you don't want to pay inflated Morgan parts prices Good tool, but the first time I used mine, I still managed to ruin the E clip! Think when applying the spanners, I must have inadvertently loosened the centre bolt such that it introduced a very small gap between the cone face and the cylinder port. It was just enough to encourage the middle leg of the clip to get caught and it subsequently broke off! Luckily, my supplier sent me a replacement clip f.o.c. Having learnt from my mistake, all went well afterwards.
