4 members (MJF, jbk, Soleng, John Winn), 294 guests, and 44 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
JohnRH Offline OP
Hi, can any one tell me what cylinder Morgan use on the roadster? Thanks John
Think all post 93 cars with rear hub brakes use the CW 15953 cylinder either by Delphi or Lockheed. Try wolf performance for a good price. Not really worth shopping around too much as the location pins can be positioned in different places. IKf you're doing it yourself its worth ordering the installation tool as well, about £14 but makes the job quick and simple.
Ah! if it's post 2017 to 2020 they are different again!
Here you are use this link
Also try power track Ltd. my last one's from there and they were cheaper!
JohnRH Offline OP
Thanks for such a speedy response!
That is what the site is about. Good luck
The tool to help get the clip over the rear spigot is the same as a Classic Mini and are available online for around a £5iver, if you don't want to pay inflated Morgan parts prices
Yes this happened on 30/3/2017 with rear cylinder part number change to Y220002. Important for later models as apparently the roll pin is in a different position.
Good tool, but the first time I used mine, I still managed to ruin the E clip!
Think when applying the spanners, I must have inadvertently loosened the centre bolt such that it introduced a very small gap between the cone face and the cylinder port. It was just enough to encourage the middle leg of the clip to get caught and it subsequently broke off!
Luckily, my supplier sent me a replacement clip f.o.c.
Having learnt from my mistake, all went well afterwards.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
