Topics49,877
Posts837,713
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
A constant feature of my Roadster has been what I can only describe as a tooting noise from the suspension. This happens most typically when turning corners or decelerating. It seems to have got a bit worse recently. Any idea what it is and what I should do about it?
Thanks.
David 2020 Roadster 3.7 Dove Grey.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Firstly; front or rear?
Secondly; Lubrication, is everything lubricated/greased as it should be?
I believe it's the front. Lubricated about 10 months ago and only done a few hundred miles since then.
Posts: 8,686 Likes: 493
Posts: 8,686 Likes: 493 |
Try some candlewax (less messy than grease or Vaseline) rubbed into the bonnet tapes, Mogs flex a surprising amount causing noises that are difficult to pinpoint
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
Try some candlewax (less messy than grease or Vaseline) rubbed into the bonnet tapes I use some rather mature lip salve, left over from when I convinced myself I could ski !
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Try some candlewax (less messy than grease or Vaseline) rubbed into the bonnet tapes, Mogs flex a surprising amount causing noises that are difficult to pinpoint I will try that Jon (or lip salve). It had not occurred to me that it could be the bonnet tapes.
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
If you can get your car on a chassis supporting ramp with the front wheels off it may reveal witness marks to the issue. Would also give you an opportunity to inspect suspension for anything amiss. ETA: unusual but could it be a shock absorber  Removing and examining may reveal the cause of noise. You could even take car for a run without them to prove the cause. You will be surprised how little different the car feels, initially at least.
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
On my 4/4 I get a similar noise. Cause is the front springs rubbing on the king pin assembly about 1/2 way up. By removing wheels & looking through the spring you can see a vertical witness mark. Any small amount of lube will stop it, until the lube gets washed off. The rear leaf springs can also make odd noises if dry & rusty.
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
When the bulkhead tape squeaks sometimes the noise appears to come from the headlamp are (!) so a good rubbing is advised, as said before look at the front suspension for witness marks. I use Waxoyl (warmed) to lube the rear springs, has great creeping qualities.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,093 Likes: 75
Posts: 2,093 Likes: 75 |
Not so much a toot but more like a squeak some years ago on mine. That turned out to be a loose nut that attaches the wing stay to the underside of the wing arch. As that is just above the front wheel, it could easily be mistaken for a suspension issue. It just needed nipping up by half a turn or so.
