0 members (), 360 guests, and 91 robots.
+8Rich 77
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,706
A constant feature of my Roadster has been what I can only describe as a tooting noise from the suspension. This happens most typically when turning corners or decelerating. It seems to have got a bit worse recently. Any idea what it is and what I should do about it?
Thanks.
David
2020 Roadster 3.7 Dove Grey.
Firstly; front or rear?
Secondly; Lubrication, is everything lubricated/greased as it should be?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
I believe it's the front. Lubricated about 10 months ago and only done a few hundred miles since then.
David
Try some candlewax (less messy than grease or Vaseline) rubbed into the bonnet tapes, Mogs flex a surprising amount causing noises that are difficult to pinpoint
I use some rather mature lip salve, left over from when I convinced myself I could ski !
I will try that Jon (or lip salve). It had not occurred to me that it could be the bonnet tapes.
David
If you can get your car on a chassis supporting ramp with the front wheels off it may reveal witness marks to the issue. Would also give you an opportunity to inspect suspension for anything amiss.
ETA: unusual but could it be a shock absorber thinking Removing and examining may reveal the cause of noise. You could even take car for a run without them to prove the cause. You will be surprised how little different the car feels, initially at least.
On my 4/4 I get a similar noise. Cause is the front springs rubbing on the king pin assembly about 1/2 way up. By removing wheels & looking through the spring you can see a vertical witness mark. Any small amount of lube will stop it, until the lube gets washed off. The rear leaf springs can also make odd noises if dry & rusty.
When the bulkhead tape squeaks sometimes the noise appears to come from the headlamp are (!) so a good rubbing is advised, as said before look at the front suspension for witness marks. I use Waxoyl (warmed) to lube the rear springs, has great creeping qualities.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Not so much a toot but more like a squeak some years ago on mine. That turned out to be a loose nut that attaches the wing stay to the underside of the wing arch. As that is just above the front wheel, it could easily be mistaken for a suspension issue. It just needed nipping up by half a turn or so.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
