2 members (DJC, Socalm3w),
366
37
Posts837,277
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Clemens
PlusFour Red Baron MY 2022
Posts: 564 Likes: 79
Posts: 564 Likes: 79 |
The folding mini wind block looks a well thought through design.. is it possible to gather some dimensions of it extended?.. The Plus Six is wider than the Plus Four, so any dimensional info would help to see if it could be fitted.
With the Pin, the wider Part is about 110 cm. I just put this on my PlusFour as a test. ![[Linked Image]](https://tm-img.com/images/2024/03/24/IMG_3647.jpeg) ![[Linked Image]](https://tm-img.com/images/2024/03/24/IMG_3649.jpeg)
Clemens
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
The frame on yours looks thicker than on my older one...I wonder if there are different models/sizes? Pm sent to you
Clemens
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Thanks Nick & Clemens
Posts: 31 Likes: 11
Posts: 31 Likes: 11 |
I made a slip-on wind breaker for my PlusFour CX headrests which works very well. Doesnβt need any fittings and the material just folds up flat when not in use. ![[Linked Image]](https://i.ibb.co/NWGSFr4/IMG-8326.jpg) Created it from a sheet of wind deflector material from here: Wind Deflector material. Sewed some webbing to three edges of a 29β wide by approx 20β long section, then fitted elastic to the edges such that 8β folds over top and down the front of the headrest, with the remaining 12β down the back of the seat. See photos - hopefully they explain how to make itβ¦ ![[Linked Image]](https://i.ibb.co/pn3JvqJ/IMG-9323.jpg) (Was posted previously here: https://www.talkmorgan.com/ubbthreads.php/topics/785308/my-top-twenty-cx-tweaks)
Posts: 8 |
Does it help with the wind noise at all?
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
My perspex blocker doesn't reduce noise at all, but does reduce buffeting from the rear.
