My 1994 +8 had just done 27k mls when it developed a potential gearbox problem.
Odd. What was it? Very curious as always.
The gearbox won't come out from below so it was an engine out job.
Yes. A characteristic of many cars, including our generation of Plus 8s (1977 to 2004). It is not difficult once you get used to it...just tedious, like re-doing one's front trad suspension. I have
posted three methods of removing your Plus 8 engine and I use whichever seems most convenient for the task I want to accomplish. For example, there is no need to remove the gearbox
for a clutch change, though so many, including dealers, do so.
The
GoMoG LAW OF ENGINE REMOVAL: The fear removing engines (either oneself or by hired mechanics) prejudices one's Morgan as one avoids the task until it is too late,
often leading to collateral damage and often a degraded Morgan experience until it is done. I have seen owners, put their Morgan up on stands and not use it for years merely to avoid
the task or costs of engine removal.
b]
BTW what does it cost to have a Morgan engine removed these days? [/b]
Having heard of clutch failures from 27k onwards......
Odd. I have only heard of clutch mileage that low when the clutch assembly has been improperly installed..(for example a few early UK GEMs Morgans) or from driver-related reasons. For example,
I have more than 400,000kms (250,000 miles) over three Plus 8s and I have never removed the engine for any clutch related reasons.That being said, considering the low cost of the 3 part clutch
kit,. I always replace the clutch when I have access to it. Why not? Why set up a need to replace the clutch even few 1000s miles earlier than you would have to in the normal course?
I was advised to replace the clutch plate, release bearing and clutch cover on the basis that as soon as the car is back on the road another component will almost certainly fail!
The latter part is not necessarily true but the advice to replace the entire clutch assembly rather than piece by piece is sage, for the reasons I give above.
A well respected and authoritative web site advised that all +8's take the Borg and Beck clutch kit HK9690 (but) that HK 9690 had been superseded by HK 6076 I picked one up
locally for £120. It is identical to the original. The kit was originally for Rover SD1 and Rimmer Bros cross references as RB7335PBB at a more reasonable £237. EBAY prices are from £45
Yes. You discovered the true story in two ways. Part #s change constantly and gomog has been around a long time. Your part # will change as well. In fact, all the alternative numbers I put up on
gomog 12 years ago, have changed! I removed them all. It seems to be the best policy for me. I can always source the right clutch in a few minutes...preferably within 20 minutes of the seeker,
anywhere in the world.
Never mind, the Man from Little Hallingbury always comes up trumps. A visit to his parts website quoted a clutch kit +8, 5 speed, TSC 331 for a reasonable £876.
Don't be annoyed at him. Your experience merely reveals a very long tradition from that very charming guy. It is always best to find non-Morgan manufacturer supply when one needs it. We merely
add another link in the parts sourcing chain along with an attendant loss in expert advice on that part. In this case, the MMC is not longer an expert in clutches they stopped installing using two decades
ago (if they ever were). Additionally, the marque, in 2002 (the beginning of the hard times, began turning predatory, just as all specialist and marque suppliers are now. In the case of the man in Little
whatever, he has always been the most expensive place to source anything and his quality is often suspect. I have had scares. But whose fault is this? Us or his? He has a following, based on his
knowledge of Morgans from 1950 to 1980ish. Knowledge is more important than prices. That being said.....
All dealers are bound contractually for supply to the MMC. As you have found, even prices at 1/2 those you first found are still often 5 times too high. The Bible gives the best advice, when it wrote "render
onto Caesar..etc". In this case, buy Morgan parts from Morgan sources and Rover parts from Rover sources. (shrug) We also lose the expertise that comes along with proper parts sourcing. The MMC
is no longer experts in the B&B parts they installed over two decades ago, if they ever were. And B&B has a LOT of competition in the same parts in equal quality. Glad to see you saved yourself 90% of
your original quote for the same part but there ARE other clutches worth buying The world is awash with generic 9.5" clutches.
The best current Morgan ourcing knowledge is now by CURRENT word of mouth. However, beware, Morgans, when you use the parts of others, do not always follow the same parts for the subject years.
One cannot simply buy the Rover or whatever parts for your Morgan model year. For example, European Plus 8s are very different from overseas Plus 8s, especially from 1994 to 2000.
BTW it should be mentioned that there are a range of different "performant or racing" clutches available for this engine. I have tried two before removing them. They are hard on my clutch leg after a few
hours of driving. I took the discrete advice of performant engine suppliers on the QT. The regular clutch offerings are easier on the leg and fully capable of coping with big engines. I use the regular clutch
offerings for the LR/Rover V8 though my respective LR capacity became tweaked 4.6 to 4.8l.
One other watchpoint to note with these clutches. Many people are still using the original metal throw-out bearing. It was changed ages ago. The newer ones (black) are better and quieter. However, take
care to grease the hinge points of either type on installation.
Thanks again for the help. I wish there were more like you.
gmg
