2 members (jejemek, ScottMellor), 262 guests, and 77 robots.
+8Rich 94
Posts837,275
Page 106 of 164 1 2 104 105 106 107 108 163 164
Originally Posted by sewin
Richard, thought I'd just take the opportunity to add to your example of protecting the vulnerable areas of the hand brake cable.
In fairness to MMC they do add a thick protective sleeve in the area where the cable catches the side of the diff housing. However on mine the chaffing had worn right through this protection and was beginning to work on the cable outer. A brief look from underneath didn't reveal much chance of tieing it out of the way. Will have another look when I next take tool tray out.
Ah! John, brilliant job and I have to say now..... its on my list! what an irksome job holding that all out of the way while trying to access the rear shelf! Stupidly I hadn't really registered how I hated the whole procedure until you voiced it! Now it's really annoying me! swear
Themorganeer has the design.
We've used a length of 21mm plastic overflow pipe with a bit of rubber hose on each end for many years to just simply prop the hood open, I really should make a proper alloy one as per Themorganeer's design one day
Spent an hour or so doing deep clean of leather followed by water repellent conditioner. Surprised how well it looks after close to 30,000 miles, even the drivers seat, and how easy it is to keep up to scratch. I mused that being a light colour (Brooklands Magnolia) dirt marks or areas show up well to allow extra cleaning work unlike darker colours.
Another advantage of light colours is the tanners need to use the best hides as imperfections cannot be hidden.
Oh the joy of the Cosworth engine!
Not a Cosworth engine, just the rocker cover. It was on there when I bought the car. I'm looking for one of the Ford Racing covers and, if I can find one, this one will be for sale...
PM me your email for the drawing.
After 4 years, the original strut and stop block are still doing their job on my car.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
I got the sleeves for the Panhard rod crossmember, which had to be cut out to install the Quaife differential, made and installed...
...and put the refurbished fuel cell back in.
X
X
I‘ve also got a copy of the drawing and made one for me and some German Morganeers. All of them are very happy how it works and how easy to install it is.
So thank you for the great idea and construction!
Greets René
2018 plus4 (sports green)
1 member likes this: Themorganeer
1845sailor ... what a cracking car .... lots of good stuff on it .... must be great to drive!
