0 members (),
318
43
Posts837,276
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Richard, thought I'd just take the opportunity to add to your example of protecting the vulnerable areas of the hand brake cable. In fairness to MMC they do add a thick protective sleeve in the area where the cable catches the side of the diff housing. However on mine the chaffing had worn right through this protection and was beginning to work on the cable outer. A brief look from underneath didn't reveal much chance of tieing it out of the way. Will have another look when I next take tool tray out.
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Ah! John, brilliant job and I have to say now..... its on my list! what an irksome job holding that all out of the way while trying to access the rear shelf! Stupidly I hadn't really registered how I hated the whole procedure until you voiced it! Now it's really annoying me!
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Themorganeer has the design.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Ah! John, brilliant job and I have to say now..... its on my list! what an irksome job holding that all out of the way while trying to access the rear shelf! Stupidly I hadn't really registered how I hated the whole procedure until you voiced it! Now it's really annoying me!  We've used a length of 21mm plastic overflow pipe with a bit of rubber hose on each end for many years to just simply prop the hood open, I really should make a proper alloy one as per Themorganeer's design one day
Spent an hour or so doing deep clean of leather followed by water repellent conditioner. Surprised how well it looks after close to 30,000 miles, even the drivers seat, and how easy it is to keep up to scratch. I mused that being a light colour (Brooklands Magnolia) dirt marks or areas show up well to allow extra cleaning work unlike darker colours.
Another advantage of light colours is the tanners need to use the best hides as imperfections cannot be hidden.
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Oh the joy of the Cosworth engine! Not a Cosworth engine, just the rocker cover. It was on there when I bought the car. I'm looking for one of the Ford Racing covers and, if I can find one, this one will be for sale...
Posts: 791 Likes: 143
Posts: 791 Likes: 143 |
Ah! John, brilliant job and I have to say now..... its on my list! what an irksome job holding that all out of the way while trying to access the rear shelf! Stupidly I hadn't really registered how I hated the whole procedure until you voiced it! Now it's really annoying me!  PM me your email for the drawing. After 4 years, the original strut and stop block are still doing their job on my car.
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
I got the sleeves for the Panhard rod crossmember, which had to be cut out to install the Quaife differential, made and installed... ![[Linked Image]](https://www.tm-img.com/images/2024/05/14/IMG_6709.md.jpg) ...and put the refurbished fuel cell back in. ![[Linked Image]](https://www.tm-img.com/images/2024/05/14/IMG_6712.md.jpg)
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Ah! John, brilliant job and I have to say now..... its on my list! what an irksome job holding that all out of the way while trying to access the rear shelf! Stupidly I hadn't really registered how I hated the whole procedure until you voiced it! Now it's really annoying me!  PM me your email for the drawing. After 4 years, the original strut and stop block are still doing their job on my car. I‘ve also got a copy of the drawing and made one for me and some German Morganeers. All of them are very happy how it works and how easy to install it is. So thank you for the great idea and construction! Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
1 member likes this:
Themorganeer |
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
1845sailor ... what a cracking car .... lots of good stuff on it .... must be great to drive!
