Topics49,864
Posts837,579
Posts: 66 Likes: 1
Posts: 66 Likes: 1 |
Hello everyone.
Does anyone know the thread type of the small screws which hold the lower frame bar to the upper section, using the angle brackets? I have broken some (rusted in) and need to drill and tap them again. The thread outside diameter is 3.5mm. There is a thread test board at the local hardware shop but not for small sizes.
It might be UNF or even BA. I could take them out to 4mm metric but would prefer to keep the same size if it can be identified.
+4 1986 - Royal Ivory / Blue Volvo 123GT 1967 - Pearl White / Brown (pristine and very rare)
Posts: 8,678 Likes: 412
Posts: 8,678 Likes: 412 |
Can only add they are metric M4 screws on later models. Be careful to check length though as some are shorter than others. Be even more careful if re-tapping. In either case contact with the glass can cause shattering!
Note M3.5 screws exist so worth a check. 5BA has major diameter of 3.2mm and 4BA 3.6mm if it helps.
Posts: 99 Likes: 1
Posts: 99 Likes: 1 |
Neil--I have a 1986 +4 Fiat twin cam. Mine appear to be Metric M4 as pointed out by Richard. I have owned since new so the screws have never been changed. Suggest replace with stainless and maybe add a little anti-seize when replacing.
Posts: 66 Likes: 1
TomS - I have new brackets (complete with screws) from Melvyn Rutter so I just need to fit them. The old rusty ones can be discarded. As a matter of interest the threads are 2BA (one screw) and 4BA (three screws).
