4 members (Pigiron, RichardV6, Hamwich, Wouter), 237 guests, and 45 robots.
+8Rich 92
Topics49,839
Posts837,301
#801082 27/05/24 08:03 PM
B3MOG Offline OP
Does anybody know where i can get a length of rubber to replace the running board rubbers , mine have gone soft and keep coming out of the aluminium strip, they have done well to last 40 years.
David Byrne
Try Woolies they are very good to deal with, enthusiasts and cheap.
Or another option here I've used them over the years and also good service.
Same company, all part of the Vintage and Classic Spares Group based in Malvern.
That explains the same pics then.
Yes, and the same prices - sadly (in my opinion at least) Vintage and Classic bought out a number of small companies servicing the same market, including SVC and Flexolite. So the products are pretty standard across the board. Their stuff is good though - I particularly like the new Toby range of lights which is expensive, but at least you can now buy a set of lights rather than waiting for old ones to come up on ebay.
when you cut the rubber cut longer than you need as they shrink about 1" longer is a good idea... you have been warned.
Do consider changing the running board bolts holding the treads down to stainless.
Triumph Herald 1969 13/60
Morris 1970
1 member likes this: RichardV6
B3MOG Offline OP
thanks for the replies, is it 12mm wide or 15mm wide rubber strip?
David Byrne
