4 members (Grumpy2, nestor59310, +8Rich, IcePack), 214 guests, and 37 robots.
+8Rich 82
Luddite 50
Posts837,942
#801406 04/06/24 01:05 PM
SCX358G Offline OP
Having just changed to 15 inch wheels on my 1977 plus 8, I'm a bit bemused by the size of the wheel studs on the rear wheels. The don't seem sufficiently long to extend fully through the wheel nut. In fact, they only engage with about 50% of the internal thread of the wheel nut. This clearly is unacceptable.
Here's the hub:
and the stud protrudes 22m:
Is this a bit short? Does anyone know the dimensions of the stud ? (I see they are available at BHM and MR but they seem very expensive).
The previous wheels had the solid version of the wheel nut, so the amount of thread engagement was never visible.
Dave
Sorry can't help 7 X 16" Centrelock alloys here.
TBM Offline
My 72 has M14 x 1.5 thread wheel studs (although it is 4 stud, not 5).
According to this website, you should have about 9.5 turns of the nut
https://www.drivenproducts.com/blogs/wheel-and-wheel-accessory-terminology/minimum-thread-engagement
Dave, I seem to remember that they are7/16ths unf. you can get longer replacements from some of the fast ford rally shops. they are stronger and cheaper than from morgan. They are the same size as the early escorts.
Hope this helps.
David Byrne
Although the website is a bit dated and leans toward American accessories don't let that put you off.
www.raceways.co.uk/American_Wheels.htm
The chap is called Tim, and he recently helped out another Plus 8 owner I know (1987 car) who needed nuts and those difficult to find inserts for the alloy wheel stud holes
