1 members (RedThree),
169
51
Topics49,843
Posts837,336
Posts: 5 |
Hello. I'm wondering if anyone knows of any availability of a front amber turn indicator lens for a 2021 M3W. Is it only available as a complete unit or is just a lens available anywhere. My lens just has a small crack.
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
You can’t buy just the lens, you have to buy the complete sealed LED housing that sits inside the pod. Aftermarket suppliers only sell in pairs, but you get two for the same sort of money as buying one from Morgan.
Omne trium perfectum
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
1 member likes this:
Bunny |
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
unfortunately when I had to replace mine, it is because the topp bolt of the shock had worked loose and the mount pivoted with the housing sitting on the muffler... I just bought a pair (only replaced the bad one) from JP Cycles... they do not match but cheaper than buying from Morgan
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
I wish somebody would do LED replacements (complete units) for the horrible quality orignals on recent Trads.
Posts: 5 |
How is the turn indicator housing removed? It looks like the attach nut must be removed from inside the pod. Does the front plastic ring snap off?
How is the turn indicator housing removed? It looks like the attach nut must be removed from inside the pod. Does the front plastic ring snap off? The front bezel is held on with a small self tapping screw.
Posts: 5 |
Thanks. I just got it apart. My 2021 M3W has no tapping screw, but what looks like just a ring is a collar which surrounds and holds in the LED sealed unit so you just have to pull it out.
