2 members (mph, Julian BB), 268 guests, and 89 robots.
Topics49,847
Posts837,389
#802152 19/06/24 04:24 AM
Hello. I'm wondering if anyone knows of any availability of a front amber turn indicator lens for a 2021 M3W. Is it only available as a complete unit or is just a lens available anywhere. My lens just has a small crack.
Toys for Boys
Toys for Boys
You can’t buy just the lens, you have to buy the complete sealed LED housing that sits inside the pod. Aftermarket suppliers only sell in pairs, but you get two for the same sort of money as buying one from Morgan.
Omne trium perfectum
https://www.carbuilder.com/uk/led-55mm-indicator-amber-lens-pair
You need to cut off the 3 mounting tabs to fit on the M3W
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
1 member likes this: Bunny
unfortunately when I had to replace mine, it is because the topp bolt of the shock had worked loose and the mount pivoted with the housing sitting on the muffler... I just bought a pair (only replaced the bad one) from JP Cycles... they do not match but cheaper than buying from Morgan
Rodger
2004 Plus 8 (wife's)
I wish somebody would do LED replacements (complete units) for the horrible quality orignals on recent Trads.
How is the turn indicator housing removed? It looks like the attach nut must be removed from inside the pod. Does the front plastic ring snap off?
The front bezel is held on with a small self tapping screw.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Thanks. I just got it apart. My 2021 M3W has no tapping screw, but what looks like just a ring is a collar which surrounds and holds in the LED sealed unit so you just have to pull it out.
