7 members (ch44, RedThree, Graham, G4FUJ, B3MOG, KLASG, High Hamster, Soleng),
222
59
Posts837,266
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
I present the magnificently imagineered and understated Medusa, built by a friend on a London cab chassis for around £1,000. Long may these eccentric creatives enrich our world of motoring. ![[Linked Image]](https://tm-img.com/images/2024/07/01/md.jpg) ![[Linked Image]](https://tm-img.com/images/2024/07/01/mdd.jpg)
1 member likes this:
Luddite |
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 5,432 Likes: 465
Posts: 5,432 Likes: 465 |
John V6, all 12 of them....??? Looks to be a very special special indeed...
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Looks to be two straight 6s in tandem under there .... bet that turns heads 🙂
Presume it's someone's outstanding toy and it can't race in vintage events like some of the modern builds using period chassis and engines?
There was a video with soundtrack on FB and it sounded glorious. On the theme of going large, this was new to me but what a beast. I can't get my head around the layout just yet though This helps..![[Linked Image]](https://tm-img.com/images/2024/07/02/napier-deltic.jpg) The mind-boggling gearing on the Napier Deltic engine. The Deltic is an engine famous for its complexity and ambitiousness. It is a triangle-shaped, opposed-piston, valveless, supercharged, two-stroke diesel engine with a displacement of 88.2 litres (5,382 cu in). The engine was essentially comprised of three opposed (boxer) engines, with a crankshaft in each corner, forming a triangle. This eliminated the need for cylinder heads thus reducing weight. Each cylinder contained two pistons, with a total of 18 cylinders and 36 pistons. It produced a maximum of 2,500 hp. Development began in the 1940s, and over its career it powered trains and naval vessels, including a few German Schnellboots. Another comment on the post fwiw "We had one a HMAS Cerberus, what a beast"
Posts: 8,663 Likes: 488
Posts: 8,663 Likes: 488 |
^^ "Each cylinder contained two pistons"
Posts: 513 Likes: 56
Posts: 513 Likes: 56 |
Richard, there is one in the York railway museum , well worth a look.
Also saw something similar in the Deutch museum in Munich
David Byrne.
Thanks David, I’ll slot that one away in the memory bank as it must be an impressive bit of kit. Just got to the bottom of my Wiki link with said beast. ![[Linked Image]](https://tm-img.com/images/2024/07/02/1024px-Napier_Deltic_Engine.jpg)
^^ "Each cylinder contained two pistons"  [quote=CooperMan] The Wiki link helps Jon.
^^ "Each cylinder contained two pistons"  The Wiki link helps Jon. Thanks Richard, makes interesting reading on the Naval development & use
