0 members (), 330 guests, and 25 robots.
+8Rich 93
Posts837,277
#802832 03/07/24 09:13 AM
HIND Offline OP
What is the procedure for carrying out a brake fluid change on the M3W.
Gordon
2013 M3W
1972 MGB Roaster
1967 Morris Mini Super Delux
Syringe out the old fluid from the reservoir fill with new fluid and bleed brakes, don't forget to also bleed the clutch as it uses the same reservoir.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
HIND Offline OP
Thanks Roger G
I have not checked yet but does the Brake and Clutch Master cylinder have bleed nipples. Also the clutch slave cylinder is that fitted with a bleed nipple?
Gordon
2013 M3W
1972 MGB Roaster
Originally Posted by HIND
Thanks Roger G
No
No
You cannot access the slave cylinder - the only bleed nipple for the clutch is in the clutch line/elbow where it enters top of gearbox bell housing under the oil tank.
HIND Offline OP
Thanks for to info. Stevo666
Gordon
2013 M3W
1972 MGB Roaster
