Posts837,278
Posts: 72 |
What is the procedure for carrying out a brake fluid change on the M3W.
Gordon
2013 M3W 1972 MGB Roaster 1967 Morris Mini Super Delux
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Syringe out the old fluid from the reservoir fill with new fluid and bleed brakes, don't forget to also bleed the clutch as it uses the same reservoir.
Posts: 72 |
Thanks Roger G
I have not checked yet but does the Brake and Clutch Master cylinder have bleed nipples. Also the clutch slave cylinder is that fitted with a bleed nipple?
Gordon
Posts: 360 Likes: 36
Posts: 360 Likes: 36 |
Thanks Roger G
I have not checked yet but does the Brake and Clutch Master cylinder have bleed nipples. Also the clutch slave cylinder is that fitted with a bleed nipple? No No You cannot access the slave cylinder - the only bleed nipple for the clutch is in the clutch line/elbow where it enters top of gearbox bell housing under the oil tank.
Posts: 72 |
Thanks for to info. Stevo666
Gordon
