Morgan Aero 8
4 members (John Winn, Alistair, chanteclair, RichardV6), 304 guests, and 58 robots.
+8Rich 95
Posts837,266
#802881 03/07/24 08:48 PM
Beard Offline OP
I think it was Simon who kindly showed me the headrest pads on his light blue Aero at at the Brands Hatch Morgan day at Goodwood. I've followed his example and had the team at Allon White make me a set also.
I'm very pleased with the result and the team in Cranfield were great to deal with, so I thought I'd pass on the recommendation.
[img]https://tm-img.com/image/VLtVS[/img]
This is the image
1 member likes this: Beard
- looks great but be careful you don't lose them when 'pressing on'..... drive
I have the same type, made by Allon Whites and they had a tendency to lift due to wind turbulence.
I fabricated some light alloy strips which go under the headrest 'pockets' and attach to the seatbelt guide bolts; see images below -
James thumbs
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Beard Offline OP
Thanks James - Allon White have supplied some velcro fasteners to reduce the risk, which they did mention. I'll have a think about what else I might do.
Beard
p.s. Nice V8 mascot - your car looks great.
cheers ! thumbs
James
Monkey Z125
[quote=James B W]- looks great but be careful you don't lose them when 'pressing on'..... drive
Yes, I've had a couple of sessions grovelling around in hedges to retrieve my passenger pad that had made a break for freedom.
I really do like your idea James, are those alloy strips riveted into either side of the leather pad?
David
Aero S4
- yes David;I made them from a bit of alloy strip and bent them to the shape of the seat top curve.
I then put a rivet at either end to secure the alloy strip to the pads, covering the rivet heads with a leather patch.
They are then attached to the actual seat by using the seat belt guide mount - so only attached at one side but this seems to work just fine.
James
Monkey Z125
Many thanks James, they do look spot on. cheers
David
Aero S4
- thanks David thumbs
Forgot to mention (it was a while ago!) , I used a strip of scrap leather/suede to cover over the alloy strip, inside the headrest if that makes sense?
The idea was that it would add a little adhesion to the strip but also stop the alloy marking the top of the seat should I wish to remove them at any time.....
HTH , James
Monkey Z125
thumbs
David
Aero S4
