1 members (Alastair), 335 guests, and 28 robots.
+8Rich 94
Posts837,276
#803401 11/07/24 08:32 PM
My newly aquired 2008 +4 seems to have long brake pedal travel before getting to the the start of braking point. It pulls up fine once you reach that point but I find it off putting. Any ideas?
Have you tried changing brake fluid which needs doing every two years anyway? As an interim just bleeding brakes starting with caliper nearest master cylinder may improve matters. Use DOT4 fluid.
Does it change if you pump the pedal. If yes they need bleeding.
If not you can change the length of the rod from the pedal at the clevis pin to change the travel
Although it won't cause excessively long pedal travel (but does add to the slop/play) it is worth checking the clevis pin as they can wear to almost nowt as some on here have found
Very true. Probably worth replacing while you are getting back ache in the footwell.
This is how they get over time smile One of our group posted this about 5 years ago now, he was a very lucky boy..
That picture was almost certainly of a clutch clevis pin since not only does it get much more use but it's of smaller diameter. Important to check both though.
I re-engineered the whole pedal and linkage system a few thousand miles ago with proper threaded stainless clevis forks, new pins and a pedal assembly with replacement phosphor bronze thrust washers given one was missing ex factory! It also allows easier adjustment since only one locknut is required.
This left a particularly smooth clutch action which remains so.
Spot on Richard, I got carried away in my enthusiasm to find the image in my gallery grin2
Now that i much better !
Auto adjust maybe not working on rear brakes. Then set up hand brake correctly
Simon
2002 4/4
2021 Audi A1 sport
