3 members (Image, sprinty, Clipper), 256 guests, and 74 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,615
Moggo
Sorry Nick that reply should have gone as a response to the previous poster ‘CBY’. I. Realise they are not a complex lock but i want to explore the more measured options before trying to pick locks, that and I cant transport a locksmith around with me to lock and unlock them. If I can’t get anywhere with Morgan or the manufacturer a locksmith will be my next port of call. Many thanks Graham
Originally Posted by +8Rich
Checked but my numbers are differing, no help sorry.
Many thanks for checking.GW
Originally Posted by nick w
Originally Posted by Juteruns
Many thanks for your observation. I realise the security of the vehicle is no way dependent on the door lock. However, the problem really is the latches that secure the hood to the bodywork at the rear. If i can’t undo these then I cant remove the hood to fit the tonneau nor can the hood be properly tensioned, relying on the windscreen frame latches to do so.
I meant undo them by jiggling. If you can't do it yourself speak to your local locksmith..theyll do it for you in ten seconds
On my much later Roadster the door locks have keys in the (now very old) FS series as used on series Land Rovers to name but one. You can buy keys if you know the number or maybe a new lock barrel with matching key.
Given there are five pin positions on a barrel and five positions for the rectangular hole within each pin you have 125 combinations.
