7 members (Image, MavisTheMorgan, Gramrugby, sewin, Grumpy2, sbarracl, Biggle), 198 guests, and 31 robots.
+8Rich 92
Topics49,838
Posts837,294
IcePack Offline OP
Done, only needed about 6 mm of tightening.
Made a tool to hold inner nut. Box spanner 11mm cut down to 40mm length.
Found it easy to hold inner nut & after releasing outer lock nut, to turn the cable “grip” that allows a spanner. Then release inner nut & let cable go back to it’s static position then Re engage tool on inner nut turn cable grip repeat as necessary.
1 member likes this: +8Rich
IcePack Offline OP
Thank you all.
