14 members (vbalddave, 2949olivier, Fuel.inj, Montegue, nestor59310, Image, Alan Patterson, Strathaven, nick w, stumog, +8Rich, MartinB60, Guten, Graham, G4FUJ),
287
42
Posts837,283
Posts: 14 |
Are AVO shocks adjustable on a 2008 +4
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Not as factory fitted.
If your car has adjustables fitted, there will be a knurled knob at the base of the front shocks - easily visible while you are under there with a grease gun. A previous owner will have fitted them - but not necessarily upgraded the rear shocks. Again, you are looking for a knurled knob at the bottom end.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Lokk up GoMog , great info on there
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
There is a school of thought that not long after new shocks are fitted, road tested and adjustment tweaked, that after a while re-adjustment has very little effect
Posts: 14 |
Thanks for the info, looks like previous owner fitted them. I am looking to soften them as the pot holes in our area are ruining the pleasure of driving the car.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Thanks for the info, looks like previous owner fitted them. I am looking to soften them as the pot holes in our area are ruining the pleasure of driving the car. Are your leaf springs well lubricated? (motor cycle chain oil does the trick)
First grease the front & the leaf springs. The leaf springs make a big difference
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
Thanks for the info, looks like previous owner fitted them. I am looking to soften them as the pot holes in our area are ruining the pleasure of driving the car. Are your leaf springs well lubricated? (motor cycle chain oil does the trick) Following advice on TM I bought some of this at my local motorbike specialist https://www.ebay.co.uk/itm/334650441499It is white, and unlike the (purple) ACF-50 that I have used previously, sort of sets into a gooey layer. As I don't have a hoist I did the job from above, with the folowing notes: 1. cover the garage floor (I used a decorator's plastic sheet) as it WILL run all over the place 2. I used a long / angled brush (like for painting the back of a radiator) which gets the grease into all the nooks and crannies 3. the 200 ml size can was enough to do the job and leave enough for next time 4. the result after 24 hours of waiting for the lubricant to penetrate thoroughly, was a satisfying improvement in the rear springiness.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
If you have only just acquired the car, please check the date code on the tyres. If they are over 7 years old, then change them - the transformation in the car will surprise you.
Also, check the tyre pressures. Most people run at 22psi all round. Too high will really affect the ride.
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
Thanks for the info, looks like previous owner fitted them. I am looking to soften them as the pot holes in our area are ruining the pleasure of driving the car. I suggest you remove one, not a big job and check to see if they are still serviceable. I had these fitted probably 15k ago and they were knackered. Now fitted with Cain of Wolf Performance adjustables, world of difference.
