8 members (JohnHarris, RichardV6, DickJ, TBM, Tresco, Rudolf, Strathaven, Grumpy2), 198 guests, and 74 robots.
+8Rich 73
DaveW 52
Topics49,867
Posts837,619
Moggo
#806627 29/08/24 07:08 PM
Barry13 Offline OP
the 4 dash switches on my 4/4 2016 one for fog light one is the hazards and heated screen the one top right does not light up should it the book says aircon which i have not got oris it just to fill the hole?
Barry13 #806636 29/08/24 08:16 PM
Online NoMood
Not sure if air con was an option on 4/4 Barry. The 4/4 wiring schematic shows no wiring for such in chassis loom unlike +4 and Roadster. Having said that the fourth switch hole is probably fitted with a redundant switch just to fill hole as you suggest. In this likely case it could be used to control something else - front fog or spots for example.
Barry13 #806639 29/08/24 08:52 PM
Barry13 Offline OP
Yes Richard it must be to fill the hole but it is a switch but no light as long as its nothing at fault i like things working thanks
Barry13 #806651 30/08/24 06:52 AM
Online NoMood
If it's just a plain switch Barry it will not be connected to anything hence no light. Referring to my comment above your chassis loom will have redundant wiring already there for optional front fog or spot lights though should you wish to add them at a later date.
Barry13 #806653 30/08/24 06:58 AM
Barry on my 2011 4/4, if the switch is pushed to it’s on position just clicks. If you then put the heater fan on, it will then light up.
I believe it is a redundant air con switch.
Barry13 #806698 30/08/24 04:55 PM
Barry13 Offline OP
Thanks for the info ive never seen it light up with the fan on but i only found it would press in last night so i will give it a go when on my next adventure have a good weekend all.
Barry13 #806709 30/08/24 07:38 PM
Online NoMood
Bear in mind Barry that a new generation of Morgan electrics came into being from 2014 onwards which certainly applied to Roadster and Plus 4, likely the 4/4 as well. The switches became electronically latching via a BCU (body control unit), toggling on or off with a single press. An LED within switch illuminated when it was turned on, at other times it illuminated in dimmed mode, hence my comments your extra switch is probably not connected.
The advantage of this form of latching was that any selection was dropped (with exception of hazards) when ignition switched off. Very helpful if rear fog lights or screen heat for example had been on immediately before.
