5 members (Moggo, BobtheTrain, Sir Percival, BillHart, RichardV6), 476 guests, and 42 robots.
Adam12 68
+8Rich 67
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,385
Members9,215
Rbt Aero8, Salmon, stevends
SCX358G Offline OP
Can anyone advise me on the correct torque setting for the rear axle castle nut on a 1953 plus 4 ?
Many thanks
Dave
The big 7/8 UNF one?
I've usually gone for about 130 ft lb plus a little bit more to get the split pin holes to line up.
Couple of points:
Make sure the key is properly fitted in the keyway - else you will split the hub as you tighten the nut.
Make sure you have a nice fitting split pin
Arwyn
SCX358G Offline OP
Many thanks, It's this one (which is marked as 32 MRA1060 rear axle shaft nut 7HA) in the spares book
When I undid it, all I could tell was it was tightened to more than the 140 lb-ft limit of my admittedly rather cheap torque wrench.
Is a 7HA axle expected on a 1953 plus 4?
many thanks for the help.
Dave
Online NoMood
Arwyn raises a good point about split pins. Don't be tempted to use the next size up just because it snuggly fits the hole with nut removed. It will make later removal far more difficult, there should be some slack.
Don't go too smaller diameter though, the head should fill most of the gap between castellations to ensure pin stays in required orientation.
Bear in mind there are metric and imperial sizes.
Be wary of using stainless pins in tight fitting spaces as it may be difficult to bend ends over and worst still when you want to straighten them when removing - I'm thinking of those securing pedal linkage clevis pins here.
If you have to cut pins down to suit make sure one end is left a little longer than the other to ease splitting and bending to secure. Use long nose pliers with serrated ends to grip before bending.
Finally they are correctly called split pins not cotter pins innocent
Imperial split pins are getting a bit hard to find though. All of the assorted split pins sold these days are metric sizes.
A 1953 car should have a 3HA but to be honest things like the hub securing nut are common to both the 3HA and 7HA axles so it's probably the right nut despite the 7HA part number. Interestingly the 3HA and 7HA inner oil seal carries a 3HA part number
Arwyn
Online NoMood
Arwyn
I've got plenty and more readily available on eBay.
