6 members (Doug J, Craig Jezz, Bitsobrits, Zach, Image, RedThree), 279 guests, and 36 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,356
Christoph
#807203 06/09/24 07:23 PM
MOG42 Offline OP
Just trying to figure out how rain and washing water drains from the opening for the spare wheel - assuming it does?..
MOG42 #807206 06/09/24 07:32 PM
Yep, more holes and ventilation than a colander
MOG42 #807210 06/09/24 08:22 PM
MOG42 Offline OP
Ha ha many thanks
MOG42 #807223 07/09/24 06:49 AM
FWIW I tended to get water collecting inside the spare wheel, at the bottom edge of the wheel where the tyre wall was sitting on the surface. I solved this by taking the wheel off and glueing a small black plastic shim across the position that the tyre wall would sit. Shim is about 4-5mm thick and about 70mm long by 20mm wide. The water now drains down either side of the shim when the tyre gets water in the centre.
MOG42 #807270 08/09/24 09:45 AM
I took the disc off the other day it was very cruddy inside gave it a good clean and a waxoil. there is quite a bit of wasted space in Morgan terms shame you cant get access to it. A hatch between the speakers perhaps.
