2 members (Socalm3w, sprinty),
336
53
Topics49,844
Posts837,360
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
Just trying to figure out how rain and washing water drains from the opening for the spare wheel - assuming it does?..
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Yep, more holes and ventilation than a colander
Posts: 245 Likes: 5
Posts: 31 Likes: 11
Posts: 31 Likes: 11 |
FWIW I tended to get water collecting inside the spare wheel, at the bottom edge of the wheel where the tyre wall was sitting on the surface. I solved this by taking the wheel off and glueing a small black plastic shim across the position that the tyre wall would sit. Shim is about 4-5mm thick and about 70mm long by 20mm wide. The water now drains down either side of the shim when the tyre gets water in the centre.
Posts: 2,432 Likes: 66
Posts: 2,432 Likes: 66 |
I took the disc off the other day it was very cruddy inside gave it a good clean and a waxoil. there is quite a bit of wasted space in Morgan terms shame you cant get access to it. A hatch between the speakers perhaps.
