3 members (Luddite, TBM, Image), 248 guests, and 81 robots.
+8Rich 77
Topics49,870
Posts837,670
Rudolf
Page 3 of 6 1 2 3 4 5 6
Originally Posted by John07
I've just fitted Cain's new front shockers to my +4, the improvement in ride has been really worthwhile.
Cheers
John.
I have the full set, so much better than the AVO'S.
I've SSL set up at both ends so the rear is not so simple. I'm moving from Spax and it's good to see them go in the bin.
I shall have to contact Protech for some specials over the winter or I could see what better shocks SSL can offer.
Air suspension gives a similar progressive spring assistor effec, but with the additional bonus if adjustable ride height.
Harald
Harald
Originally Posted by Hamwich
I'll contact Roger and see if he has any bump stop spring assisters left.
Yep, well worth fitting if you can get hold of a set, they are truly excellent.
Another plug for these gizmos. One of the most worthwhile improvements to a trad IMHO.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Cain makes great kit so I am not surprised
Well I can really vouch for Rog's suspension assisters, They are probably one of the best mod's you can fit on a trad standard rear end. Remember the original Mini, it came with rubber cone suspension and it was a service free system that really worked. They changed to hydro-elastic suspension but towards the end of production reverted back to rubber cone! Rog's assisters work like that in that they have a progressive damping effect when normally you would hit a fairly immoveable stop and depending on suspension travel and shock absorber functional length could cause a fair amount of damage. It is probably one of the best spends you'll make! and again to Rog.... thanks for my ride comfort!
I'm coming up to wanting a change in my rear shocks, 12 years old and still original Fuchs, working ok but must be tired! I've been waiting for Cain's to hit the market as I know just how much research has gone into them and you can adapt the rear angle if needed to prevent that rotational damage caused to the mounting points. Wolf only sell/produce good gear so that's where I'll be going next!
LONG..BEWARE. Some thoughts.
To truly cure something, you must understand what is amiss, what is the ultimate goal is and only then figure how to achieve it. Amateurs shun logic and are inexplicably beguiledvby ready made stuff, sold to them at a huge profit. Professionals try to make one size fix all (the only way they can sell one-size-fits-all. Each trad being the different is not a profit maker. So they treat Morgan trad as if they all have the same degree of stiff chassis, which they definitely do not. Trad chassis flexing chassis is an individualized major flexing factor for each, different before it is installed, changing with the installed equipment, owner's driving style and leaf spring quality. Leaf springs per se are actually more sophisticated than coil overs, especially for flexing chassis. They spread spring effect over a large area on a flexing chassis rather than focusing those forces to small points which become weaken and alter the chassis over time to sad effect. Leaf springs can infinitely shape the comportment of the car in unlimited ways.
In front, Peter Morgan once wrote me he used shocks them in front as customers thought a front end was odd without them.The all-important suspension travel in front is only 1.-1.25 inches, though Cain and the MMC owner race preparer are working on this, I believe successfully. I am excited by both of them. I have never found another car (aside from go carts) with so little travel but remember the flexing chassis is also a delicious part of the trad suspension that we have loved for more than 100 years. We merely cannot quantify it save one car at a time. As is, the only vital needed action in the front is to cut down the silly, too long rebound spring. A Factory mistake and misunderstanding adopted after HFS left. I have been doing so for 30 years at the suggestion of JH2. It is costless but now huge amounts are made by a Morgan supplier essentially doing the same thing. However, rather than being almost costless, they charge for other unnecessary add-ons, make-the-car-more complex add-ons. And they will NOT sell you their rebounds only. A tragedy for the less mechanically enabled. I should add a article on how to shorten trad rebound springs on gomog. Actually, a neoprene bump stop made to the right specification would be ideal. Cheap and smart. Neoprene did not exist 90 years ago.
The rear travel is only about 4-5.25" Exceed either travel, either back or front and you "bottom out". And I tell owners when they think something is wrong at the front to remove their shock and go for a drive on their personal test road, back-to-back and report. There are more of the wrong dampers installed in the front than proper ones! That one suggestion opened up an entire new era of understanding for Button.
Springs have a different task than dampers[/u. ]After your tyres they are the first line of road comfort and comportment. But most people buy price and longevity in tyres even for their hobby. Travel is the distance ride height divides the sprung and the unsprung weight. That is where springs and shockers work.
[u]Dampers have another task.
More sophisticated than generally understood. They change the oscillations of the spring suspension to something humans find comfy. Get that wrong or truncate it and the cars become painful. Shocks MUST be made to match the existing travel, where it is and and the correct dampening for your car. Only three Morgan damper sellers in history, namely Rutherford, Tim Ayres and hopefully now Cain (I just ordered a full set a first after many years of buying shocks..watch this space) ) have sold dampers made for Morgan. Others, including the MMC and other after marketeers, use whatever is popular for the moment, or cheap for them for one reason or another. (not that the most expensive shockers are always the best, that is a function of extension, where the extension is and the dampening rate and as noted, Morgans are very different from all other cars.). The chance of coincidentally matching Morgans with shocks not SPECIFICALLY made for them (despite what the ubect manufacturer says) is by wild luck only. (That can happen as it did with only KONIs) The fact shocks are adjustable is an inventory feature allowing fewer shocks to cover many cars. You will notice that large auto manufacturers do not sell adjustable shocks for their cars. innocent
Here is the part that is going to get me disliked. But unlike today's world, I do not write to be liked or sell anything. I write merely to collect lore and what I have learned and share it. People believe what they want to. THE GoMoG LAW OF EXPENDITURE: "The likelihood of a car enthusiast reviewing anything he has already purchased with passionate approval is directly related to how much money he spent on it." like Button and Sheally and some pros, most people follow this Law. Our bunch toss everything that does not better the car or make it simpler. I tossed a small container load of such stuff last year.
1. As badly made leaf springs sag, the all important travel distance changes and diminishes. Ergo, the car bottoms far more frequently. It is curious fact that their spring rates do not change no matter how much they drop, but with a truncated travel you bang your way down the road . Easy to check. Your car at rest should be approximately mid way between the shock extension)
Using even very excellently made bump stops merely tracks the deterioration of your rear suspension. Those who use them want to change the unwanted and ever more frequent BANGs to more pleasant sounding THUDs. Their suspension and handling is no better. Degraded suspension, if any is left at all. The goal should be to have the best possible suspension and not to find elegant ways to adapt to a lousy one.
I stopped trusting MMC leaf springs in this area 20 years ago. I like the quality of the steel used by the latest toast of the town, but his offering of leaf springs to act as anti-tramp as well indicates a basic misunderstanding of leaf spring technology and merely trying to please the market. Imagine adding something to prevent coil springs compressing! Coil springs can be adjusted by preloading them but leaves have proper hope of adjustment, though the US sells leaf spring height adjusters. Leaf springs, ideal for trads, are not adjustable without tampering with their spring rate. Rob Wells tried something similar 25 year, made for him by a very reluctant Peter Mulberry, They made the cars back breakers. Grounds for divorce. When I asked the current fellow for springs rates..I stopped getting answer to my emails. BTW, very few trads have a need for anti-tramp. Most models don't have it or can drive around it. I need it with my 300bhp and a very light Plus 8, but I use Mulberry anti-tramps which do not effect comfort. The leaf springs can still work. (Avoid the MMC copies!). Only downside is every 10 years or so you must press out and replace the cushioning at the ends. Also be frightened of the MMC one-side only antitramp. They were trying to save money to avoid the tramp having the drive train hit the propshaft cover on Roadsters, but having a single anti-tramp eventually twists the chassis. Logic rules once again.
3. I have been idly looking for a leaf spring maker for years. Leaf springs technology and maker is more advanced in North America and Australia with all the long distance truckin, there is one along every few miles along every highway. Their turnaround time is amazing as the trucks have to get back on the road ASAP. But I have too much to do and I am aging..[b]which is enhancing my looks of course. [/b🙂 Without leaf springs to recommend, I cannot suggest a proper rear suspension for trads. Shocks yes, anti-tramps, panhards yes (there is a cheap costless substitute) . But it all starts with the right leaf springs. Only those with the few non-sagging leafs from 2004 on or the earlier springs can be helped. Anecdotally, Kevin Vernon and I installed 4 sets of leaf springs in two years when we were restoring my UK Morgan. The Factory fare all collapsed within weeks of using them. I was lucky to have been saved using very deep connections. As another fact, the old style 5 leaf springs delivered with the car the MMC built for me in 2002. I insisted on 5 leaf and they are still fine. The rear has dropped 5 mm. That being said I place my Morgan on stands if I am not using it for 2-3 days or more.
4. Lowering blocks or lifting blocks are a cheap solution for leaf springs with the wrong arc or design. They accordingly provide another back breaking "solution" to ride height. Does the picture posted show a huge bump stop to address sagged springs while using a lowering block to lower the same springs? Why?
I admire the quality of work of these bump stops. They will provide a very precise and ongoing measurement of how much one's rear suspension has collapsed and the anticipation of worse to come. expectation of more. I do so wish this production expertise can be used to address the real problem. We need people such as these.
gmg.
Paul F Offline OP
I’m sure that Peter Mulberry will be thrilled to be told that his leaf springs are badly made.
Costock, UK
Disco 5
You should merely have asked for clarification Paul, but so few people do these days. And is that the point you wish to add to this
discussion? I will answer both.
Peter is one of my very dearest friends. We are both retired and correspond constantly, on everything from Morgans to life. Right or
wrong, we are heroes to each other. I will not go on for fear of embarrassing him. In any event, both Rob and Peter have done so
much for the marque they are pre-forgiven for all time. Neither ever failed to explain something to me.
And Peter never made leaf springs, IIRC. I spoke to an addon, shackles made at Rob's insistence. Considering Peter and Rob's
relationship, I understand that completely.North American truckers do that often to support heavier loads. They are not interested in sports
car handling and comfort.
Shackles, their type, the number of them and their placement change how the leafs act. They most often change the spring rate drastically.
One can also use the steel spec and thickness to achieve the same thing. One chooses springs for every vehicle by their spring rate. Yes
you can make leaf springs so stiff that they become, virtually, tramp preventers. The price is the loss of proper leaf spring dynamics. Rob's
addon only sold for a short time before it was removed from the market. The bad back plague ended. I have an old Morgan mate whose wife
wrote me to thank me 20 years ago when her husband removed the device. What should one assume when the vendor will not tell you his
resultant leaf spring rate? That being said, an improvment in steel quality is a HUGE step in the right direction.
I use 140-145 rear springs, the same spring rate of my front main springs (marked "Plus 4") even in 2002 when they were not making Plus 4s
How about you? The MMC has played around with lower springs rate since PM passed, along with many suppliers. What have you chosen to
use?
gmg
GMG
I find this an interesting discussion (forgive my use of laymen terminology and not being technically minded and a complete novice in this field of understanding), so from what I understand a shortened ( preferably progressive) rebound spring, all other things being in good order, is all that is really necessary to improve the front suspension compliance and ride. Does a shortened rebound spring in any way effect the ride height?
If I wanted to say raise the ride height and improve the ride comfort how would I go about it at the front, as ground clearance is always an issue fully loaded, I'm more interested in outright touring comfort than out and out handling but would not want to compromise either too much.. The thought of having to adjust shocks for each different type of journey, is not something I would look forward to.
I have a 2012 Plus 4 sports, so from what I've read so far at the rear the condition of the leaf springs is far more critical to the cars road manners. I've over the years heard mention different numbers of leaves in the springs and having mention of using the 4 seater springs, having had a Roadster 4 seater, I wasn't to impressed with that set up at all, as I felt the power overwhelmed the rear setup too easily. So what is the best number of leaf springs and their rating for my setup and most likely the best rear suspension setup I should look to achieve. I must admit the current standard setup (only covered 5k miles) is pretty compliant but that will change with time. I don't have BRB's fitted and have found them when fitted to improve the front end feel under braking, but on both Morgans they have been fitted too, it has restricted the turning lock is there any workaround to that/or a question of who supplied the BRB.
I appreciate there are many varied views in this, but would appreciate your input.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
mph Offline
The rebound spring doesn't affect the ride height.
Unfortunately in some Morgans the rebound spring is under compression which is not good as, contradictory as it may seem, it adds to the stiffness of the main spring resulting in extremely stiff front suspension. As GoMog has suggested, a simple improvement can be effected by shortening the rebound spring so that it is not compressed under static conditions.
I'm going to look into this on my recently acquired Plus 8 as a first step.
There will be numerous opinions on improving the rear suspension and I'd be surprised if a consensus will be found on this forum ! Generally speaking, using leaf springs as a suspension medium and as the ONLY means to locate a live axle is not good practice, unless for modest power outputs.
I envy MGB owners, they have numerous upgrades available to them. From fibreglass or parabolic springs to every location device under the sun all available off the shelf from the MG club or various independent specialists.
I'd recommend the book " How to Improve your MGB, MGC and MGB V8" by Roger Williams, it has so much useful and informative information that could also be applied to Morgans, particularly the V8.
