5 members (Graham, G4FUJ, Simon Bamford, uvk33n, Scrambledsignals, Morganmike), 230 guests, and 36 robots.
John V6 65
DaveW 63
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
The Stanley Tour 2025
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Topics48,350
Posts813,120
Members9,212
Ivo
Hi all,
I've been trying to chase down a long term, extremely intermittent fault on my +8 - It occurs very infrequently and currently only after some harder (motorway type driving).
The issue is the engine will sometimes run really rough - possibly missing on one or more cylinders and then cut out when I stop. A reset of the ECU (remove/replace the red key) will usually get me going again. I have done all the usual checks and changes with no success. So I started to drive the car with a laptop connected and logging ECU data with Rover Gauge. Last weekend I think I finally caught the issue. Just before the engine cut out (as we approached a junction) the data shows the engine speed going to 5800rpm! It clearly didn't and the rev limiter would have cut in to prevent it going that high.
Following a bit of research I found there should be a 6K8 Resistor in line from the neg side of the coil to the ECU input pin for engine speed.
I took a look at the car and found two 6K8 resistors - both connected to the neg side of the coil.
The spade contacts all looked pretty manky and resistance measurements weren't as expected, so I cleaned them up and confirmed they then measured around 6K8 ohms. So this maybe the fix.
But I don't have any idea why there should be 2 resistors and the wiring doesn't seem to match anything I can find. I will continue to buzz out the wiring to see where it goes (White background blue stripe - one of the Resistors has a red sleeve over it as well.
Any advice or info would be most welcome.
Thanks
Kev
1995 Plus Eight
2021 Plus Six
This may or may not be relevant but when I had problems with my CUX14 ecu the cause was traced to pin34 which tells the ecu what type of gearbox is fitted and what to do with the idle speed. Mine had gone resistive so was telling the ecu I had an auto box and it was doing all sorts of odd things. A rewire (brave) via. 510ohm resistor to watch changed the Rover Gauge to Manual and gave a nice smooth consistent idle at 850rpm.
Might be worth a check - I missed it for some time.
Thanks I'll take a look.
1995 Plus Eight
2021 Plus Six
In the case of a Disco, with manual transmission, the second resistor provides an engine speed feed to a trip computer. I believe that it is used to allow the trip computer to determine if the engine is running
Mike Smith
2007 +4
Again, in the case of a Disco, the pin 34 on the ecu is connected via a diode to the park/neutral switch on the auto box, which connects to earth when in park or neutral. Thus allowing the ECU to raise the idle when not in park or neutral. In the case of a manual box pin 34 (via the diode) is earthed using a 480 ohm resistor.
Mike Smith
2007 +4
Thanks Mike - for both those snippets really useful.
I'm building up a number of thing to investigate when I next get a chance.
1995 Plus Eight
2021 Plus Six
