7 members (RubyMog95, mph, JohnHarris, Fuel.inj, Luddite, DCH, Saxonian),
284
76
Topics49,877
Posts837,713
Posts: 730 Likes: 58
Posts: 730 Likes: 58 |
Hello MOG Members
A number of jobs to do over the Winter months. I have been looking at the Dashboard forum tonight and i figured this Winter i would like to change the Speedo and Dial which incorporates the Water temp, Oil, Volts and Fuel. Both dial our the original Smith dials. Just change them over. As mentioned in the Dashboard forum, when you have the tonneau cover fitted it's quite hard to see the speed. Is this possible? If it is, it it a easy job?
As normal many thanks for your help in this matter.
Navy Dave 1976 Morgan 4/4
Posts: 6,672 Likes: 439
Posts: 6,672 Likes: 439 |
I've thought about this myself - the only real issue is ensuring the wiring/cables/capillary tubes are long enough to swap positions.
None of it insurmountable, especially if you are doing it over a period of time so can get longer tubes and extend the wiring if needed.
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
You could consider changing to Left Hand Drive? Sorted !
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
I don't know about the '76 model but for later models the wiring loom is the same for both RHD and LHD cars. Several people have swapped the instruments in the last series of pre-CX trads.
My feeling is that it should be possible and fairly easy to do.
