0 members (), 311 guests, and 33 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 3 of 4 1 2 3 4
[Linked Image<br>See the smaller lower wire. This is the other end of the “Bowden” cable from the dash control. I used some mintex brake grease to lube the cable. It is high temperature tolerant. You gain access via a heater vent, which are held in via a spring clip across the back.</div>
<br>
</div>
<div class=
Funny my text gone missing.
Smaller wire is the other end of “Bowden” cable from the dash control i lubed it using mintex brake grease as high temp tolerant. Access via one of the vents that are held in via a spring clip across the back.
Mind you Morgan have changed how they control the heater every 5 mins it would seem. Mine 2011 4/4
The removed Vent.
[Linked Image</div>
<br>
</div>
<div class=
What’s the technique for removing and replacing these vents in their housing box?
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
By the look of it Chris, a similar technique to fitting/removing ceiling spot lights. Typically two spring loaded tangs grip and hold blindly in place. Gently prizing out one side of fitting then bending tangs towards each other when able should allow withdrawal.
Agreed - it must be as you say Richard.
It was access to the tangs that I struggled with in an incredibly awkward location.
Chris
The way I got it to release was to gently pull the vent until the frame was released. Then move it to one side & using long nosed pliers, “jiggled” the wire free. Then move the vent unit the other way until it releases. Replacing is the opposite, but caution the wire clip does not interfere with the heater controls.
Mine was also a bit brittle & getting oneself across the seats on your side with both arms free was kind of entertaining.
IcePack #767878 26/01/23 08:11 PM
I know the feeling 🤪
Chris
Reviving this topic as mine has gone a tad stiff, so first off, thank you Craig for posting this.
For those with a 4/4, does your heater control knob just turn or do you have clicks? I did a few searches on TM and a few have posted that they do in fact have clicks/indents on the heater knob but it's not clear if that is a Plus 4 only thing or not.
Perry.
On my 2003 Zetec engined 4/4, there are no clicks when turning the heater control,
Mind you, to call it a ‘heater’ is a bit of an exaggeration.
The driver gets a warm lower left leg; the passenger, a warm lower right leg, as long as you don’t knock the vents shut with your leg.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
Page 3 of 4 1 2 3 4
