0 members (),
271
87
Topics49,847
Posts837,389
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
My 22 car doesn't have a sound system but removing the rear panel shows the wiring. I have sourced from a breakers in Poole a system from a 20 car.
Can anyone help with photos or descriptions of where the bluetooth streamer , volume control and associated wiring go/ can be found I can find anything obvious and before I start taking the front appart would hope someone can help.
Posts: 141 Likes: 3
Posts: 141 Likes: 3 |
John, I'm not certain but the current bluetooth reciever may be one of these bluebird The amp is a Kenwood kac-m1814
The streamer is from simple and the amp is the earlier 1804. Here is what I bought
Sorry I hope this link works. Click here
Posts: 72 Likes: 6
Posts: 72 Likes: 6 |
Sorry I hope this link works. Click hereNope! "This listing was sold....." Please could you list the items? Thank you
So four speakers. An isimple bluetooth streamer plus volume control, the amp and cables plus what I think is a DAB ariel with the blue connector. ![[Linked Image]](https://tm-img.com/images/2024/10/26/6.jpg) ![[Linked Image]](https://tm-img.com/images/2024/10/26/1.jpg) ![[Linked Image]](https://tm-img.com/images/2024/10/26/2.jpg) ![[Linked Image]](https://tm-img.com/images/2024/10/26/3.jpg) ![[Linked Image]](https://tm-img.com/images/2024/10/26/4.jpg) ![[Linked Image]](https://tm-img.com/images/2024/10/26/5.jpg) It is where the connectors for the isimple streamer & the RCA leads are hidden behind the dash I need to know. Also if I am wrong on the blue connected ariel then where does that go. Thanks in advance.
Posts: 33 Likes: 9
Posts: 33 Likes: 9 |
the streamer is hidden in the panel above the passengers right knee. (tried to reply earlier, post never appeared) I hardwired to the volume control via a phono to mini jack. then an adapter for music & usb charging. subsequently replaced with a quad lock mag charger (for charging)& music out via the bottom connector. I prefer the volume control rather that using iPhone buttons. streamer wasnt very good. I had the Kenwood system ripped out as it was pretty poor. .. depends how much you enjoy your tunes I suppose. I started removing/loosening the panels under the dash from where the door hinge is .. fairly straightforward.
Thanks. I not expecting hi fi sound quality.
