7 members (Laurens, JoeSpeetjens, sbarracl, Mike D, MartinB60, Topline123, PaulyG), 202 guests, and 58 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
John V6 Offline OP
My 22 car doesn't have a sound system but removing the rear panel shows the wiring. I have sourced from a breakers in Poole a system from a 20 car.
Can anyone help with photos or descriptions of where the bluetooth streamer , volume control and associated wiring go/ can be found
I can find anything obvious and before I start taking the front appart would hope someone can help.
John, I'm not certain but the current bluetooth reciever may be one of these bluebird
The amp is a Kenwood kac-m1814
John V6 Offline OP
The streamer is from simple and the amp is the earlier 1804. Here is what I bought
John V6 Offline OP
Sorry I hope this link works. Click here
Nope! "This listing was sold....."
Please could you list the items? Thank you smile
John V6 Offline OP
So four speakers. An isimple bluetooth streamer plus volume control, the amp and cables plus what I think is a DAB ariel with the blue connector.
It is where the connectors for the isimple streamer & the RCA leads are hidden behind the dash I need to know.
Also if I am wrong on the blue connected ariel then where does that go.
Thanks in advance.
CRL Offline
the streamer is hidden in the panel above the passengers right knee. (tried to reply earlier, post never appeared) I hardwired to the volume control via a phono to mini jack. then an adapter for music & usb charging. subsequently replaced with a quad lock mag charger (for charging)& music out via the bottom connector. I prefer the volume control rather that using iPhone buttons. streamer wasnt very good. I had the Kenwood system ripped out as it was pretty poor. .. depends how much you enjoy your tunes I suppose.
I started removing/loosening the panels under the dash from where the door hinge is .. fairly straightforward.
John V6 Offline OP
Thanks. I not expecting hi fi sound quality.
