Posts837,278
Posts: 50 Likes: 2
Posts: 50 Likes: 2 |
![[Linked Image]](https://www.tm-img.com/images/2024/11/08/IMG_3238.jpg) Need help - I'm assuming this is a Bevel Box oil feeder tube. I believe that's what it was sold as - and I think that I have seen a photo or two of someone's installation. Can someone please confirm if that's what this is? Also, please point me towards any existing photos of it installed. I presume it attaches into the filler hole and then is fed up behind the seats / seat belts?
24 Super 3 23 Super 3 21 M3W 15 M3W 05 V6 Roadster 68 MGB GT 3.9L V8 67 MM 1000 Tourer
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
It looks like a system that was intended to be permanently fixed and increase the oil capacity of the bevel box. I'd leave it off and run with the amount of oil it was designed for.
Red Leader
3 members like this:
Bunny, planenut, Stevo666 |
Posts: 215 Likes: 6
Posts: 215 Likes: 6 |
It is the remote Oil Fill from MorganCustoms. I use it and it does work well. If you need detailed instructions for this easy modification I have the instructions in PDF.
2018 S&S 110th Beetleback 1934 MX4 Beetleback (in restoration) 1965 Corvette Coupe 327/350
1 member likes this:
MOG37 |
Posts: 50 Likes: 2
Yes, that is what I believe it is. I do not have any instructions and Emil's website is no longer functional. I would be very grateful if you could post or message me those instructions. Any photos of your install would be great as well!!
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
I have a similar line on my car that connects where the side breather once was. It is not to increase oil capacity, rather to eliminate the oil mist that came out of that breather. Also handy as a filler tube for the bi-annual fluid changes.
Steve Late 2012 M3W
MOG37 |
Posts: 50 Likes: 2
Steve, thanks. Do you happen to have any pictures of the install? Did you access via the rear wheel cover, from underneath, and / or from the front, behind the seats?
I did find a couple of photos. I forgot I plugged the original side hole and tapped a new one on top. The 'oil' cap at the end of the hose is the original one that previously mounted on the side of the bevel box. The hose goes towards the left side of the car then up. ![[Linked Image]](https://www.tm-img.com/images/2024/11/09/IMG_0147.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/11/09/IMG_0152.jpg)
Steve Late 2012 M3W
MOG37 |
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
looks like that would be fairly easy to fabricate now that Emil is gone
