0 members (), 291 guests, and 37 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
#811288 09/11/24 03:00 PM
S2K03 Offline OP
Hello
The lock signal is red when the car doesn't ride.
I try 2 keys and no problem to start the engine and drive.
What append?
Thank you
No mention of what car you have but typically the immobiliser red warning light on dash will flash intermittently when car not running to confirm immobiliser is active.
S2K03 Offline OP
Ok it's a roadster 3.7
S2K03 Offline OP
The light flash intermittently so I think it is ok
Engine off you should & key out you should get the lock signal. When running it should be off.
My lock jammed once so I removed the lock barrel & you can start the car by turning the switch that fits into the barrel. With no key in use the lock flashes but the car will drive, or at least mine did.
2025 MG ZS EV aka Trigger
Same as mine then. With the engine not running the padlock icon within speedo flashes red every 2-3 seconds indicating immobiliser active. It does this whether key present or not.
S2K03 Offline OP
Thank you very much
