6 members (Image, linklaw, Elliot, mph, A11OGE, CLPlusFour), 299 guests, and 41 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,321
Members9,215
#811288 09/11/24 03:00 PM
S2K03 Offline OP
Hello
The lock signal is red when the car doesn't ride.
I try 2 keys and no problem to start the engine and drive.
What append?
Thank you
No mention of what car you have but typically the immobiliser red warning light on dash will flash intermittently when car not running to confirm immobiliser is active.
S2K03 Offline OP
Ok it's a roadster 3.7
S2K03 Offline OP
The light flash intermittently so I think it is ok
Engine off you should & key out you should get the lock signal. When running it should be off.
My lock jammed once so I removed the lock barrel & you can start the car by turning the switch that fits into the barrel. With no key in use the lock flashes but the car will drive, or at least mine did.
2025 MG ZS EV aka Trigger
Same as mine then. With the engine not running the padlock icon within speedo flashes red every 2-3 seconds indicating immobiliser active. It does this whether key present or not.
S2K03 Offline OP
Thank you very much
