10 members (CooperMan, OZ 4/4, DaveK, Joe Speetjens, CraigL, IcePack, Mick Annick, Mogdavid, Topline123, Morganmike), 306 guests, and 28 robots.
Adam12 69
+8Rich 67
John V6 61
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,368
Posts813,416
Members9,215
Rbt Aero8, Salmon, stevends
MOG37 Offline OP
My "Number Plate Mounting Panel" rattles because its not connected to the chassis on one side. According to the Parts Book, the connector is a countersunk M6 x 25mm flat head socket screw. One the one side, the screw is tight and holds in place. On the other side, the screw does not turn, but the plate moves freely in and out of the end of the chassis. Does anyone know how this is fastened inside the chassis? Is there some sort of threaded insert? I don't see any references in the Parts Book. I doubt the chassis tube itself is threaded.
Any photos would be appreciated. Thanks in advance.
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
I believe that there is a threaded insert. I have always had problems with the screws working out and have reverted to using Loktite there and on so many other points of this car. It is, after all, literally trying to shake itself apart!
1 member likes this: MOG37
A rivnut - maybe just buy a kit of them from Amazon et al?. Just changed my socket screw to a bulb head M6x25 to hold a badge bar, and added a locking washer.
MOG37 Offline OP
My two flat head socket screw will not unscrew. I don't want to force it until I know how it's connected inside. There are gaps on the side of the tube chassis. I presume a squirt of WD-40 or lubricating oil through that gap might help?
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
I would use proper penetrating oil not WD40, if the issue is purely that screws will not unscrew, and left for 24 hours. Then use the correct 4mm hex (allen) socket on screws. Failing that drilling off screw heads then drilling out remaining thread to allow re-tap may be only course of action.
It appears though that one of the tapped welded in chassis plugs has loosened so you may need to get that re-welded in place.
I am shocked! innocent
Rodger
2004 Plus 8 (wife's)
MOG37 Offline OP
Correct! It is a Rivnut. Here's two photos of the good side...
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
MOG37 Offline OP
Abd here's a couple of photos of the bad Rivnut... looks as though it pulled through somehow. I figure it wasn't installed properly in the first place. There shouldn't be enough force to pull the Rivnut through that hole!
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
"There shouldn't be enough force to pull the Rivnut through that hole!"
Oh yes there is enough vibration especially if the screw was over tightened, which is a not unusual occurrence.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
The plate mounting panel is heavy and the vibrations do, in time, pull the rivnuts out. A good solution is to replace the rivnuts, and replace the steel panel with a much lighter aluminum one.
Another approach is to get rid of the rivnuts, and tap threads into the forward face of the mounting tubes. Even though that will require a larger, non-countersunk mounting bolt, it may solve the vibration problem. Note that the forward faces of the mounting tubes are rather thin, so tapping threads into them may put one into the experimental mode, as far as longevity goes.
One may take a Dremel tool and open the orifice of the forward mounting tube (shown in the above picture), then, using a hemostat, insert a nylon locknut behind the forward face of the tube. A modified wrench will hold the locknut for tightening of the mounting bolt.
If a front license plate is not necessary, replace the rivnuts, dispose of the steel panel, and install a 1-1/4X1/8" aluminum angle, 20.5" long, polished. That gives an excellent aesthetic to the V-twin engine above it.
