1 members (Alastair),
330
42
Posts837,276
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Last year, my local eagle-eyed MOT tester noticed a small drip of coolant somewhere from the rear of my 2 litre Duratec engine, onto the bell housing and down to the ground. He suggested I keep an eye on it. This I did for the past 3k miles, and with a piece of cardboard under the car, I had a very small wet patch appearing. Over 6 months, I may have only needed to add a cupful of top up. Having checked the hoses, doubled up on the clips, the drip prevailed and would accumulate under the thermostat housing manifold pipe, which sits hidden under the coil pack. Apparently, they are notorious for failure due to being plastic. I sourced a Quinton Hazel replacement from ebay for about £30, and having changed it out, the drip has been cured. I was hoping to see a nice crack on the old one but nothing is obvious. It is quite a complex moulding with many moulding seams.
Although it is difficult to see in detail, once the air filter, coil and mounting plate have been removed, it is relatively easy to change out.
Incidentally, Ford POAT coolant which has been orange for many years, and went by the moniker “Super Plus” , now has a new spec WSS-M97B57-A1 and is now coloured green. Ford say it is compatible with the previous spec. and can be safely mixed.
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Interesting and thanks for the pointer Doug. Mine lost a tiny amount over last summer. Its been teasing me for a while. I suspect its leaking somewhere as I get an occasional whiff of coolant when driving. Haven't been able to find any drips yet, even at the back there.
Roger 2011 Plus 4
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Different engine same problem. Mine’s a Zetec and I had a slow loss of coolant which I couldn’t find. Eventually it got worse (after a trip to Cornwall) and I traced it to the thermostat housing. Removed it and there was a small section of the seal retaining wall warped allowing it to leak. New housing fixed it.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
I think it is the same thermostat housing on the Sigma 1600 in my 4/4. Same symptom in mine started 3 years ago as a slight weep. New housing fixed it. Not easy to fit on a Sigma as the thermostat housing is directly beneath the alternator.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
I read this thread because I also had a coolant drip, but it was under the left hand side of the radiator. There is a small weak point in the radiator design in that an 'O' ring in a the mounting of a small spiggot on the top of the radiator can start to leak. I suspect quite a few owners have replaced their radiators because they could not find a small spare part or the source of the leak- Mattmog put me on to the solution, and then I found a reference which gave us the part number on, of al places, a Ukrainian forum. Here is the photo of the part, showing the part number, that Mattmog purchased. ![[Linked Image]](https://www.tm-img.com/images/2023/04/11/DSCN5360.jpeg) I carry a spare in the Morgan just in case I get a failure on a trip. I mention it here because, although the source of the leak is different, someone might find this thread while searching for a solution.
1 member likes this:
SwissMogFan |
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Good find Peter, looks like it's made in Germany (I wonder if the OE rads are too ?)
Good find Peter, looks like it's made in Germany (I wonder if the OE rads are too ?) Sorry I should have mentioned that the original part number was for Mercedes-Benz. I would imagine that Morgan sourced a radiator that was used in some Mercedes-Benz or BMW model rather than having a custom radiator built. I sourced my spare from a Mercedes dealer but the Ukrainian forum was for BMW owners. The Ukrainian gave the Mercedes part number but it was for his BMW. He could not find an equivalent BMW part. In reality it is only the 'O' ring that needs replacing but it is almost impossible to remove the spiggot without breaking it. The plasticis probably somewhat "cooked" after several years in boiling temperature water. Below is the translation of the post that was on the Ukrainian BMW forum: BMW 7 series A bit of Mercedes in my car or a small radiator leak from the return connector calypso Was 5 hours ago I drive a BMW 5 series Gran Turismo (BMW 7 series before that) Kiev, Ukraine I have noticed some fogging of the antifreeze on the top of the radiator, where the air bleed hose comes to the return connector. Was observed only when cold. Seems like the o-ring has dried out and is leaking slightly when the car is cold. Trying to gently pull it out to replace the ring I eventually broke one of the three anchors, and then I got a surprise. BMW is like that, it doesn't come as an individual part, you have to buy the radiator assembly... Good thing other manufacturers are smarter, and I found some info on the internet that this part is perfect for a Mercedes. I decided to use it because it can be delivered the next day. ![[Linked Image]](https://a.d-cd.net/5666c45s-960.jpg) Part pictured: A0005000894. BMW 7 series (E38) Parts pictured: A0005000894 ![[Linked Image]](https://a.d-cd.net/8966c45s-960.jpg) Mercedes A 000 500 08 94 Hella 8MY 376 743-321 BMW 7 series (E38) You can clearly see how the O-ring is shrunken Price: 4 € Mileage: 393,000 km Plastic outlet. A0005000894 MERCEDES Cooling system connector 8MY376743321 HELLA 12 Oct 2017 Tags: breakage 2 Previous Expansion tank
Graham, G4FUJ |
