0 members (),
254
42
Posts837,276
Posts: 4 Likes: 1
Posts: 4 Likes: 1 |
I just bought a new Morgan and I do not know how to change the time on the clock? any help. Thank you
Jose Fernando Santisteban
Posts: 8 Likes: 1
Posts: 8 Likes: 1 |
I had the same thing & found it depends on what clock you have. On mine I have two very small holes in the clock face and then you use a matchstick to push in and change the time. 1 does hours the other minutes. I believe theother type is button under neath the clock in the dash.
2019 Plus 4 110 anniversary Edt. 1999 Honda VFR800 Fix 1974 Triumph Daytona
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
My PlusFour has the two holes mechanism, only to be operated with a pointy object. My 4/4 has a Smith clock with a turn knob you have to push for fast rotation, and to turn for precise setting. I must say that the old clock is far better, runs perfectly in time and is good readable. Not everything is progression.....!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
There is a small push button on the dash undertray between the wheel and the door.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
It's the tiny button in the middle of this photo, as John describes above ![[Linked Image]](https://www.tm-img.com/images/2021/11/02/20211102_153054_resized.md.jpg)
Posts: 4 Likes: 1
Posts: 4 Likes: 1 |
Thank you for your help. I found the bottom under the dash and I was able to change the time.
That's completely new for me....!!🤔
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Thank you for your help. I found the bottom under the dash and I was able to change the time. Yes hold button in and hands will motor around quickly. A tap of button will move hand one minute.
