0 members (), 295 guests, and 26 robots.
+8Rich 94
Posts837,276
I just bought a new Morgan and I do not know how to change the time on the clock? any help.
Thank you
Jose Fernando Santisteban
I had the same thing & found it depends on what clock you have. On mine I have two very small holes in the clock face and then you use a matchstick to push in and change the time. 1 does hours the other minutes. I believe theother type is button under neath the clock in the dash.
2019 Plus 4 110 anniversary Edt.
1999 Honda VFR800 Fix
1974 Triumph Daytona
My PlusFour has the two holes mechanism, only to be operated with a pointy object. My 4/4 has a Smith clock with a turn knob you have to push for fast rotation, and to turn for precise setting. I must say that the old clock is far better, runs perfectly in time and is good readable. Not everything is progression.....! innocent
Ruut Bianchi
There is a small push button on the dash undertray between the wheel and the door.
It's the tiny button in the middle of this photo, as John describes above
Thank you for your help. I found the bottom under the dash and I was able to change the time.
That's completely new for me....!!🤔
Ruut Bianchi
Yes hold button in and hands will motor around quickly. A tap of button will move hand one minute.
