10 members (verysideways, Saxonian, JMcL, Image, Ruut Bianchi, aerotaff, BobtheTrain, Zach, davewhite, Pipmac),
266
36
Topics48,337
Posts812,923
Members9,203
Posts: 59 Likes: 3
Posts: 59 Likes: 3 |
Hi guys, we are to remove front and rear wings on our 1973 +8, as they need some care and a respray. What is the correct and easiest way to do so? Are there a specifici sequence of which parts to remove first etc? Cheers /Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
Posts: 5,041 Likes: 312
Posts: 5,041 Likes: 312 |
I found this site a really useful reference when I was rebuilding my '75 4/4. https://morganrebuild.co.uk/K PS The first thing in the 'Bodywork' section is removing the front wings
Posts: 11,854 Likes: 137
Posts: 11,854 Likes: 137 |
Back in those days the rear wings were held on by bolts, the heads of which can only be accessed by peeling back the upholstery over the wheel arches. These days, they use threaded inserts so that hey can be accessed from underneath.
Your original bolts are going to be knackered anyway, so I recommend grinding the nuts off and drilling new holes for threaded inserts, that way you don't have to disturb the inner wheel arch covering.
The front wings are held by easily accessible nuts and bolts apart from the sections under the body tub, these are also nuts and bolts and likely to be just as knackered as the ones on the rear wings. Again, use threaded inserts when you put the wings back.
When I did this job a few years back my steel wings were very rusty and rather than attempt to restore them I put on a set of fibreglass wings from Sid Watson. Best thing I ever did to the car, Sid got such a good match with the resin colour that I didn't even have to paint them.
